Exhaust Baffle
Davy Doherty
Exhaust Baffle
Where would i get the wrapping/packing material for one of my baffles anyone got any idea's
- paul doran
baffle
sheffield insulation do a fire retardent insulation. which we use in building's
under new building regs. it'll last longer than normal insulation.
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
packing stuff!
I managed to get the proper stuff you need from these guys:
Might be worth a phone call, as a lot of the old hairdyers use it in their tailpipes!
www.scooters.co.uk
[/url]http://www.scooters.co.uk/editorial.asp?d=2&c=&e={A43388B1-AC7B-4A4B-AABB-C3CD76302523}[url][/url]
www.scooters.co.uk
Hi dont use rockwool it disintergrates too readily i have some of the gen stuff i had off some MX specialists near me i will see i still have the address or i may be able to find the stuff i have Cheers Paulj...
Davy Doherty
PAULJAC47 wrote:Hi dont use rockwool it disintergrates too readily i have some of the gen stuff i had off some MX specialists near me i will see i still have the address or i may be able to find the stuff i have Cheers Paulj...
Ok i'll give it a while to see if you can come up with some Paul,maybe you would PM me if you do.. if not i'll ring around and see what happens thanks for the advice lads
If the baffle comes fully out get the stuff that comes in a stitched sheet it's much easier to put on, I use cling film to keep it in place while sliding the can over it.
http://cgi.ebay.co.uk/EXHAUST-BAFFLE-PA ... 18Q2el1247
Davy Doherty
paul doran wrote:Pigford wrote:A lot of the MX boys re-pack their exhaust quite regularly......
Maybe Busters or M&P or an Off-road specialist
get real
Davy use a good quality fibre glass insulation
it is as close to the original as you can get
You can be a real pratt sometimes Paully
