Rim offset
1GOM
Rim offset
#1 PostAuthor: 1GOM » Wed Dec 03, 2008 12:30 pm
I'm hoping someone can help with a question re wheel rebuilds. I've searched the forums and can't find the answer.
I'm rebuilding my Z1A(US model) and as part of that process have delaced both wheels to enable vapor cleaning of the hub and rechroming of the original rims. Being a bit of a pillock I didn't look to see whether there was any off set of the rim prior to delacing. Is there any offset to either front or rear whel ar are the rims laced centrally?
I'd be extremely greatful for any advice offers
Dave
steve
#2 PostAuthor: steve » Wed Dec 03, 2008 1:42 pm
Dave,
I have this info written down somewhere in one of my notepads from when I've stripped Z1 wheels in the past. I'll try to dig it out for you...please be patient though!
Steve
MaineKZ
#3 PostAuthor: MaineKZ » Wed Dec 03, 2008 2:25 pm
Hi Dave
I just merrily de-spoked my wheels with a bolt cutter - so you're not alone!
That said, it's not a disaster: the general rule is that if LH and RH spokes on a particular wheel are the same length - and I believe they are on the Zed range - then rim must be centred on hub spoke flanges.
Bit of accurate measuring and simple maths will give you the centre point and the appropriate distance between the outer edge of the rim and a convenient flat datum point on the hub (ie disc mounting surface or lip of brake drum).
Your wheel builder will have no problem in setting them up correctly
#4 PostAuthor: chrisu » Wed Dec 03, 2008 3:08 pm
i did the same as you. just threw them at Hagons and said rebuild please.
never noticed any detrimental effect on the handling :shock:
1GOM
#5 PostAuthor: 1GOM » Wed Dec 03, 2008 3:34 pm
Thanks guys - I did the same with another bike in the past - youd think I'd learn'
One point is that spoke lengths are different left to right on both wheels.
Steve - I can be very patient - it's freezing in my garage!!!! Again thanks to all
Dave
Garn 1
#6 PostAuthor: Garn 1 » Wed Dec 03, 2008 7:59 pm
1GOM, I sent a rear rim (oFf a Z1) to the eletro-platers and unbeknown to me, they sent me back a chromed Z1000-A2 rear rim. Now here is where the difference is.
The rear wheel of the Z1, Z1A, Z1B and Z900-A4 are all the same... no offset and symmetrical rear hub. However, the Z1000 with its rear disk has unequal size rear hub flanges and to cater for this, they have one side the rim spoke-holes drilled at a sharper angle. There is also a small arrow indicating the direction on the "Takasago" rim.
It is impossible to respoke a Z1000 rim (rear disk) to a Z1 series, large rear hub.
To answer your query, the front & rear rims of the Z1A are laced centrally.
There was a slight offset in the Z1B and this was not in the spoke lacing, but rather in the rear sprocket, by way of a packing plate, to accomodate the alignment of the thicker O-ring chain.
RegardZ.
david edgcombe
Z1-Z900 A4 rear wheel restore
#7 PostAuthor: david edgcombe » Tue Dec 09, 2008 8:32 pm
Dave,
Am in the process of restoring an original Z1-Z900 rear wheel, with a straight edge placed on the cush drive flange the rim off-set is around 20mm. I can send a pic of this if I could work out how to attach it to this message!
DogsbolloxofZ1B
#8 PostAuthor: DogsbolloxofZ1B » Tue Dec 09, 2008 8:51 pm
Your not bothering with the rest of the bike then. :lol:
1GOM
#9 PostAuthor: 1GOM » Thu Dec 11, 2008 10:07 am
Thanks Garn 1. Sorry for the delay but computer went up the swanny!
BTW how's Sydney? Used to live there
Cheers again
Dave
steve
#10 PostAuthor: steve » Wed Dec 17, 2008 4:26 pm
Dave,
I have found my sketch of the rim offsets that I measured from a 73 Z1 but not sure how to post a sketch on here. I've therefore sent you a PM for your e-mail address.
Steve
Samanthaz1000
Re: Rim offset
#11 PostAuthor: Samanthaz1000 » Thu Jan 20, 2022 4:12 pm
Dave did the same thing here didn't measure first , surely my kz1000 rear disc wheel is so heavily built that offset isn't that critical to a couple of mm considering how most bikes have been dropped and the frame weakness , I cannot find the offsett demension in the UK some wheel builder offered to sell it to me , pretty fed up might just put the cast wheels back in
Samanthaz1000
Re: Rim offset
#12 PostAuthor: Samanthaz1000 » Thu Jan 20, 2022 4:14 pm
Hi Steve if you happened across a rear wheel kz1000 disc I would be so grateful
Samantha
