Z2 Block
jonhunt
Z2 Block
#1 PostAuthor: jonhunt » Mon Jun 09, 2008 4:43 pm
I have a Z2 engine, at least the casings are Z2 marked. However the capacity mark on the block is 903. Anyone know if Z2s had a specific 750 mark or did they use the same casing & just machine it differently?
Jon
z2.john
#2 PostAuthor: z2.john » Mon Jun 09, 2008 8:46 pm
Hi Jon,
The Z2 has 746cc cast on the block
John
Iain marshall
#3 PostAuthor: Iain marshall » Mon Jun 09, 2008 9:41 pm
sounds like someone has built a 900 in to the 750 crankcases,750 crank has a shorter stroke 58mm the 900 66mm,so just fitting the barrels of the bigger engine wouldnt work
jonhunt
Z2 Block
#4 PostAuthor: jonhunt » Tue Jun 10, 2008 9:24 am
Thanks. Looks like I have the bits to replace the broken fin parts on my bike. :lol:
Garn 1
#5 PostAuthor: Garn 1 » Wed Jun 11, 2008 12:10 am
Jon, it coulds have had a Z1-900 crank-shaft fitted. Which would make it work, your Z2 motor work as a 900cc.
RegardZ
