Tank liners
Skid Mark
Tank liners
#1 PostAuthor: Skid Mark » Sun Nov 06, 2022 9:17 pm
I hoped to avoid lining my ELR tank, when i cleaned it with Biox I found it was weeping around the badge fixings. I looked at replacing it but it is hard to find a good tank that is not in similar condition. I soldered it and checked it again and found more weeps. This went on for 3 or 4 times, so even now it is water tight I'm not confident it will stay that way for long. I was speaking to a lad who was into those horrible Hodnas and he recommended this product. have any of you any experience with it?
https://wagner-german-oil.com/wagner-tank-sealing
If I could sort the tank one way or the other I can get the paint work done and that's me sorted. This has held me up since April.
Thanks in advance,
P
Re: Tank liners
#2 PostAuthor: warren3200gt » Sun Nov 06, 2022 9:23 pm
No experience of that product but have used POR 15 a few times successfully. A 250ml tin is enough for one tank.
https://www.frost.co.uk/por15-fuel-car- ... KIQAvD_BwE
Re: Tank liners
#3 PostAuthor: ADRIAN H » Sun Nov 06, 2022 9:38 pm
Pot 15, is a good product if done properly, but is a devil to get out.
Personally I think it is better to repair the tank and not use a liner. Especially as it’s being repainted,
Skid Mark
Re: Tank liners
#4 PostAuthor: Skid Mark » Mon Nov 07, 2022 9:59 pm
Yes I agree but There were so many pin holes that think it will be a waste of time to get the tank sprayed unless it is lined.
I hadn't see this before and hoped it was an improvement over the other liners. It claims to be ethanol proof, but so does this:
warren3200gt wrote:No experience of that product but have used POR 15 a few times successfully. A 250ml tin is enough for one tank.
Thanks for the replies lads. I need to get off the fence one way or the other shortly!
Stugill
Re: Tank liners
#5 PostAuthor: Stugill » Tue Nov 08, 2022 7:54 am
I lined my tank in Aug 2020 with POR15, only two years but still good.
Not sure if you've seen this thread I put on, might be of use.
Stu
viewtopic.php?f=32&t=47199
Re: Tank liners
#6 PostAuthor: chrisu » Tue Nov 08, 2022 8:07 am
My H tank needed doing as it was like Swiss cheese and getting a replacement likely impossible
I ended up getting it done 5 years ago by a company called TCP tank care products
Not the cheapest approach maybe but fixed once and for all.
Skid Mark
Re: Tank liners
#7 PostAuthor: Skid Mark » Tue Nov 08, 2022 8:16 pm
chrisu wrote:My H tank needed doing as it was like Swiss cheese and getting a replacement likely impossible
Thanks for the reply Chris, did TCP weld/patch the tank or line it?
P
Re: Tank liners
#8 PostAuthor: chrisu » Tue Nov 08, 2022 10:10 pm
P
Probably both
But not sure
Bottom was cut and welded back
H tanks rarer than rocking horse poo
Mr Bump
Re: Tank liners
#9 PostAuthor: Mr Bump » Tue Nov 15, 2022 9:12 pm
Tank care products do treatment kits, I've used them twice and had no problems. The first kit I used needed the tank and sealant jollop to be heated to something like 70 degrees C, which was a pain. The kit I used a couple of years ago had been reformulated somehow and only needed heating to 30 odd degrees (I think...) to get it to flow and was much easier to use.
It's a pain of a job but worth doing in my view if you do it properly.
Olly
Lemmy
