Am i completely wrong, or can i use gpz1100 camshaft in my MK2. Sprocket size 32 teeth?…if so is ther any benefit like higher lift duration etc etc.
I have an option for a pair much cheaper than webb, andrews etc
Any advice or help appreciated as usual.
Rob
Gpz1100 camshafts
Gpz1100 camshafts
paid up member
Re: Gpz1100 camshafts
Yes! You can use them.
You will need the APE 32t /2 bolt ACS1100K-2B adaptor sprockets .
I presume you are refering to the 83-85 unitrack cams with extra lift etc ( set them at 110 degrees ) and you may have to slightly clearance the head.
All the other GPZ100B and 1000J cams are pretty much the same spec as the stock 900/1000 so not worth the conversion.
Users browsing this forum: Jigginjim and 79 guests
