Ignition problem's
Ignition problem's
#1 PostAuthor: Bill P » Tue Jun 21, 2022 5:31 pm
Good Evening Gent's
Has anybody ever had electronic ignition problem's when it wipe's out a module regular as my friend's Z650b
keep's doing it and the bizarre thing is it is alway's 1 and 4 cylinder
He is what i call a Grown Up when it come's to electric's as he's time served and wire's Furnace's etc and has
sorted that many issue's on every creed of bike for me and fully rewired some so for him to be struggling is
hard for me to believe , all suggestion's welcome :)
Cheer's
Bill
z2.john
Re: Ignition problem's
#2 PostAuthor: z2.john » Tue Jun 21, 2022 5:46 pm
is the battery in good health? Electronic ignition doesn't like duff ones as I eventually found out
#3 PostAuthor: Bill P » Tue Jun 21, 2022 5:54 pm
Thank's for reply John , we put a new on after the original Dyna failed as i have also had that same problem
#4 PostAuthor: warren3200gt » Tue Jun 21, 2022 5:55 pm
Which make of ignition is it? Dyna, boyer, khi of a later 650 or summit else?
#5 PostAuthor: Bill P » Tue Jun 21, 2022 9:24 pm
First was a Dyns S which had been on a good while but not big miles so he borrowed my spare Dyna S oops
went same way but quickly , he has checked everything electrically and it has just been running one of the
Chinese copies DS2 500miles or so to work and back now it's done it again :ooer
kz900B1
#6 PostAuthor: kz900B1 » Wed Jun 22, 2022 7:54 am
Hi Bill, Is the feed to the coils standard or via the Wired George MOD ?. I've read this can mess up the Dyna system
colinKZ900B1
#7 PostAuthor: zed1015 » Wed Jun 22, 2022 8:00 am
Charging system is the likely suspect and also faulty or incorrect coils.
#8 PostAuthor: Bill P » Wed Jun 22, 2022 1:49 pm
Hey up KZ900 he has indeed done the wired george mod i will tell him to revert back and see how it goes :up
Hey up Zed1015 he has thoroughly checked charging in past but thats one of things i keep banging on about so we will
defo recheck as for coil's what do you recomend to use as i alway's just put cheap generic one's on mine :o
#9 PostAuthor: zed1015 » Wed Jun 22, 2022 3:01 pm
Bill P wrote:Hey up Zed1015 he has thoroughly checked charging in past but thats one of things i keep banging on about so we will
With the Dyna ignition i always use the Dyna coils as you get a much stronger spark, 35k volts, much easier starting with more power and MPG throughout as there is less spark suppression.
They recommend only using their coils ( as they would ) with the green 3 ohm for racing and black 5 ohm for road but everyone just runs the green 3 ohm anyway .
Never run less than 3 ohms or leave the ign on stationary for more than five mins or so as you risk coil damage.
The black 5 ohm run a little cooler and are supposed to last longer because of this at the expense of a slightly weaker spark but they still kick out more than the stock coils.
I just run the green on all mine, the oldest set being on my everyday Z1R which has been running happily for about 23 years.
gray
#10 PostAuthor: gray » Wed Jun 22, 2022 9:06 pm
wired george mod melted my coils ( 2 sets in 1 weekend) , happened when on a long run.I set were black dynas, 1 set was std genuine Kawasaki
gray
#11 PostAuthor: z1bman » Wed Jun 22, 2022 9:31 pm
gray wrote:wired george mod melted my coils ( 2 sets in 1 weekend) , happened when on a long run.I set were black dynas, 1 set was std genuine Kawasaki
that would have been down to a charging problem or leaving the ignition & kill switch on for long periods
KWACKERZ1
#12 PostAuthor: KWACKERZ1 » Thu Jun 23, 2022 6:12 am
I have never done the wired george mod. As if you make sure your std stuff is working correctly you get enough volts to the coils.
Have run 3ohm green dynas and std 3 ohm coils with dyna s for years with the only failures being due to the bike hitting the deck.
KeithZ1R
#13 PostAuthor: KeithZ1R » Thu Jun 23, 2022 10:28 am
This does more damage than it gets credit for .....just sayin
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#14 PostAuthor: kev edwards » Thu Jun 23, 2022 3:09 pm
Plus 1 on the get rid of the Weird George mod, check charging system also.
#15 PostAuthor: Bill P » Thu Jun 23, 2022 3:21 pm
Thank's for the help Gentlemen
