Brake light failure warning switch
#1 PostAuthor: r3sc » Tue Apr 12, 2022 6:29 pm
Hi All,
Are there any viable replacement options for the brake light failure warning switch?
Regards.
Kev1R
Re: Brake light failure warning switch
#2 PostAuthor: Kev1R » Wed Apr 13, 2022 10:51 am
Not sure what bike you have but spotted this on the infamous ebay
https://www.ebay.co.uk/itm/144466604593 ... Swst9hwJWt
010
#3 PostAuthor: warren3200gt » Wed Apr 13, 2022 1:11 pm
Assuming that ebay one works that's cheap.
DavidZ1R
#4 PostAuthor: DavidZ1R » Wed Apr 13, 2022 2:39 pm
Yes correct one, but used.
Andrew_s
#5 PostAuthor: Andrew_s » Wed Apr 13, 2022 10:15 pm
r3sc wrote:Hi All,
Regards.
I bought a couple of NOS KZ/Z400 ones for my A4 from the States for about £20 a few years ago, postage isn't cheap though (£15), but try finding them over here: https://www.ebay.co.uk/itm/175237676176 ... SwP-phVMm4
Current Bikes:
2023 R1250 GSA
#6 PostAuthor: r3sc » Thu Apr 14, 2022 1:28 pm
Hi Guys,
Many thanks for the input.
Andrew,
That is the exact item I need, for a Z400.
Is there any way to test my existing unit before taking the plunge with a NOS one?
Regards
#7 PostAuthor: warren3200gt » Thu Apr 14, 2022 2:28 pm
Remove tail/brake bulb. Idiot light should flash.
#8 PostAuthor: r3sc » Thu Apr 14, 2022 5:54 pm
The trouble I have is that the red idiot light is on all the time whenever the ignition is turned on. Never flashes, never goes off??
Is there a test that can be done on the unit itself using a multi meter?
Cheers.
#9 PostAuthor: warren3200gt » Thu Apr 14, 2022 6:42 pm
If its on all the time Where's is the idiot light earthing? Is the rear brake light on/ operating cofrectly? Could be as simple as rear brake switch needs adjusting.
What happens if you disconnect the failure unit? If you do that the idiot light will only come on when your front or rear brake is applied to complete the circuit.
If the idiot light remains on with the failure unit disconnected the the circuit must be grounding someplace.
Just another thought. Has it been fitted with an led bulb in the idiot light? That would mean it stays on constantly.
There is an easy fix by adding a resistor in parallel to the idiot light or just swop back to a standard bulb.
KeithZ1R
#10 PostAuthor: KeithZ1R » Thu Apr 14, 2022 7:32 pm
Z1000 workshop manual page 211 shows you the test procedure
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#11 PostAuthor: r3sc » Thu Apr 14, 2022 7:43 pm
According to the Kawasaki wiring diagram I’m using, the idiot light bulb doesn’t have a permanent earth, it has a permanent 12v which it shares with both brake light switches and the lamp is earthed via the green and white wire from the failure warning device.
The 12v to the brake light switches is switched to the rear brake light bulb via the blue wire and the bulb itself has a permanent earth. (0v)
With this in mind it does appear the the failure warning device is providing the normally switched earth permanently which is why I wanted to try and bench test the unit.
Cheers.
#12 PostAuthor: warren3200gt » Thu Apr 14, 2022 8:10 pm
For it to provide a permanent earth through the failure unit it would show continuity across the terminals wouldn't it?
#13 PostAuthor: r3sc » Thu Apr 14, 2022 8:13 pm
Keith has identified the correct testing procedure in the Z1000 manual which is great.
I’ll get onto that in the morning and let you know.
