New shocks needed
chrispyduck
New shocks needed
#1 PostAuthor: chrispyduck » Mon Mar 07, 2022 9:11 am
The handling on my Z1a has progressively got worse with each ride being more and uncomfortable. Fed up of being fired out of my seat each time I hit a bump I was wondering if anyone has any recommendations for replacement shocks. :shock:
Currently have the replacement pattern ones that looked the part when new but after 15 years a bit tired. :cry:
I have tried Hagons on my Kettle and they seem ok but are there any better out there? :?:
Many thanks
Fat girls are like M****s, they are fun to ride, you just don`t want your mates to see you.
KeithZ1R
Re: New shocks needed
#2 PostAuthor: KeithZ1R » Mon Mar 07, 2022 4:03 pm
Koni "Dial a rides" are good and they come up second hand occaisionally the modern equivelant are Ikons I believe, but you could do lot worse than contacting hagon directly and talking to them as the are very approachable , just saying
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
davejames
#3 PostAuthor: davejames » Mon Mar 07, 2022 6:24 pm
Chris, my Z1b has Konis on it that seem to work well. There's an invoice for them from 1995 in the paperwork so they last well too.
chrispyduck
#4 PostAuthor: chrispyduck » Mon Mar 07, 2022 9:18 pm
CAT3
#5 PostAuthor: CAT3 » Mon Mar 07, 2022 9:51 pm
Have you considered these, I thought they looked in keeping & they'd be custom built,
https://www.maxtonsuspension.co.uk/files/t260-c.htm
chrispyduck
#6 PostAuthor: chrispyduck » Mon Mar 07, 2022 10:12 pm
CAT3 wrote:Have you considered these, I thought they looked in keeping & they'd be custom built,
Thanks I'll follow this up. I suspect custom built units are going to be costly.
davejames
#7 PostAuthor: davejames » Mon Mar 07, 2022 11:28 pm
chrispyduck wrote:https://www.ebay.co.uk/itm/273836326481?hash=item3fc1eabe51:g:MngAAOSw7aNc0Ya0
Not sure I want to spend this much :eek
Think mine were £130 ...... that's inflation for you!! :shock:
chrispyduck
#8 PostAuthor: chrispyduck » Tue Mar 08, 2022 9:00 am
Thats acceptable Dave. I am not expecting stellar handling just something for a comfortable, safe ride.
The Hagon website appears to be under construction :roll:
Has anyone tried the ZPower shocks?????????
Mr Bump
#9 PostAuthor: Mr Bump » Tue Mar 08, 2022 9:57 pm
Yes, i sent them back.
Lemmy
chrispyduck
#10 PostAuthor: chrispyduck » Thu Mar 10, 2022 9:53 pm
Oh :shock:
Why did you send them back :?:
From what I have researched the ZPower shocks are the best of the cheap shocks :roll:
Mr Bump
#11 PostAuthor: Mr Bump » Thu Mar 10, 2022 10:00 pm
Couple or three years ago now, but the damping was atrocious. Absolutely rock hard compression, like hardtail hard. Maybe i just had a bad pair. I ended up on Progressive shocks, which work really nicely and look good. Try contacting Motorcycle Revival for advice. Very helpful people.
It's a bit like tools or boots. Buy cheap, buy twice.
Lemmy
Andrew_s
#12 PostAuthor: Andrew_s » Sat Mar 12, 2022 11:31 am
Just bought a set of Hagons for my A4 - stainless bodies and upper shroud with chrome springs, built for my weight (85kg) at £286 delivered and pretty much look stock. Haven't fitted them yet though. I think the current shocks are OEM style from Z Power, not sure how long they've been on (I've had the bike 5 years) but they've pretty much had it.
Current Bikes:
2023 R1250 GSA
chrispyduck
#13 PostAuthor: chrispyduck » Sat Mar 12, 2022 8:38 pm
Andrew_s wrote:Just bought a set of Hagons for my A4 - stainless bodies and upper shroud with chrome springs, built for my weight (85kg) at £286 delivered and pretty much look stock. Haven't fitted them yet though. I think the current shocks are OEM style from Z Power, not sure how long they've been on (I've had the bike 5 years) but they've pretty much had it.
That seems a good price where did you get them from ?
I've pretty much decided to go for Hagons so shopping around now for best price. 5 years ago I paid Wemoto £205 for a pair of Hagons for my Kettle :shock:
Just looking at the fitting technicalities is it possible to remove the lower bolt for the shocks without disturbing the exhausts..........I am thinking do it whilst on the side stand......replacing one at a time of course.
Andrew_s
#14 PostAuthor: Andrew_s » Sat Mar 12, 2022 8:46 pm
Direct from Hagons, Part No 35007CC1 (Z1, Z900 and Z Thou) - looks like I'll have to swing the exhausts out to get to the bolts? personally, I wouldn't do this job on sidestand.
Current Bikes:
2023 R1250 GSA
