Tightening z1000 rotor bolt
Gavin
#1 PostAuthor: Gavin » Sat Feb 27, 2021 1:21 am
Hi guys
How do I go about tightening the rota bolt without having the special tool to hold the rotor and not having the equipment to make one.
Gavin
Z1000 MK2
Z1300 DFI
Re: Tightening z1000 rotor bolt
#2 PostAuthor: zed1015 » Sat Feb 27, 2021 1:40 am
Stick the bike in gear and stand on the back brake or use a strap wrench.
Mr Bump
#3 PostAuthor: Mr Bump » Sat Feb 27, 2021 8:46 am
Like the man says, a good strong strap wrench will hold it.
Olly
Lemmy
Gavin
#4 PostAuthor: Gavin » Sun Feb 28, 2021 2:48 pm
Strap wrench turned up today, £12 off Amazon,
The job it was to be used for took less than 15 seconds but worth every penny
Thanks for your advice
Gavin
Z1000 MK2
Z1300 DFI
LTD Project
#5 PostAuthor: LTD Project » Wed May 31, 2023 12:28 pm
Well, a strap wrench helped me too on this job, but try as I might, I dont reckon I am getting more than about 60 ft/lbs on the bolt....
Will that do? Not to spec I know :glare
If not, anyone got a rotor holder tool that I can borrow, near York??
LTD Project
#6 PostAuthor: LTD Project » Thu Jun 01, 2023 6:09 am
Bump… Any sage words or tool help would be great, want to get her MOT’d and on the road.
Gus
#7 PostAuthor: Gus » Thu Jun 01, 2023 7:37 am
Would somebody confirm this method before Gavin goes ahead?
If it has Alloy wheels, put a STRONG piece of wood (with some cloth wrapped around it for protection) through the rear wheel under the swing arm both sides.
Put it in gear and tighten the rotor bolt so that the wheel spoke is hard up against the wood which is then held up hard against the underside of the swing arm.
Tighten the rotor bolt.
Gus
"Set the GRINDER on it"
LTD Project
#8 PostAuthor: LTD Project » Thu Jun 01, 2023 11:00 am
Thanks Gus
The wood between alloy wheel and swingarm did the trick....95 ft/lbs achieved. Phew, much appreciated!
Now back on with the cover.
Gus
#9 PostAuthor: Gus » Thu Jun 01, 2023 11:06 am
:lol: :lol:
Gus
Users browsing this forum: Google [Bot] and 97 guests
