Z1 Twin Disc Set
Z1 Twin Disc Set
This Z Power twin disc set up has only done 200 mls at most ,removed yesterday , the discs are scored quite a bit I noticed on removal
if you thought they were a problem i would sort something with Phil for you.
- warren3200gt
Re: Z1 Twin Disc Set
Thurston engineering in Essex can regrind the surface back flat.
What pads were used? That looks to be brake pad damage. Have they picked up and got road shite inbedded on the pad contact face.
Thanks for that. The pads were the ones that came in the set, as for road grime on the pads they don't look bad and as i
said 200 miles max.
said 200 miles max.
- warren3200gt
It can only be soft disc metal, pad material or pad surface shite. 200 miles, that would have me pissed also!
Not available until discs sorted
cheers bill
cheers bill
I've seen this reported quite a few times and Phil at Z-Power is aware.
Thanks, I messaged Phil and he's sorting it . Top man that he is i got a reply on a Sunday.
If you still have them for sale I would be interested.
Please let me know either way.
Regards Derrick
Regards Derrick
PM sent
- paul doran
john westmoreland
- new poster
I interested in your twin disc the condition of the discs doesn't matter to me as I have a 4 bolt set up just so long as the rest fits my KZ1000A1 if its still available would you please message me on here and i will try to keep up ,or text me ,sorry admin remove if not aloud ,on 07778758078...
- paul doran
john westmoreland wrote:I interested in your twin disc the condition of the discs doesn't matter to me as I have a 4 bolt set up just so long as the rest fits my KZ1000A1 if its still available would you please message me on here and i will try to keep up ,or text me ,sorry admin remove if not aloud ,on 07778758078...
These won't fit Your bike they are for the early model Z1 Z1A and Z1B
Hi Bill, I’m told the callipers will fit my Z900 a4 but not the discs, do you still have the callipers and everything else?
If you do please contact me.
Regards Derrick
Regards Derrick
Hey up Derrick
i do have the twin disc set still , PM me a offer if you want
Cheers Bill
Cheers Bill
Hi Bill.
Tried everything but can’t PM you, it must be an age thing.
What sort of offer are you looking for?
If you know how to work it out you could PM me and I’ll reply.
Regards Derrick
Regards Derrick
