more questions!
jamfan
more questions!
#1 PostAuthor: jamfan » Sun Apr 27, 2008 9:02 pm
Sorry for all the questions peeps but...
My batt is flat on my b2. I've just started it with jump leads fine but as soon as I take the leads off it misses and dies. I thought the alt would charge and it run ok, but no. I haven't had time to put a tester on the alternator outlets to see if its charging but on other bikes I've had with flat batts before, once started didn't die.
Any Ideas??
#2 PostAuthor: chrisu » Mon Apr 28, 2008 4:00 pm
does the battery charge at all ? if it does and holds a charge I'd try again to see if it runs ok without the jump leads.
if it won't hold a charge it could cause enough of a drain to cause a misfire - maybe a cell has died ?
If you get it running turn the lights on and rev it - if the lights get brighter then it should be charging - thats not to say its not charging too much though.
in summary - start with a good battery and when running put a meter across the terminals - you should get about 14v if its 12 or less even when revved the charging systems is suspect.
jamfan
#3 PostAuthor: jamfan » Mon Apr 28, 2008 4:15 pm
Many thanks Chris. I'm off up the workshop now and I'll give it a go.
:D
