Standard carbs. Wanted
Anyone got a good set of standard slide carbs for sale.
Re: Standard carbs. Wanted
Standard for what? Do you want model specific, daily runner, concours?
Sorry z900 z1000 slide carbs not bothered if they are 26/28 s .
Just a good working set for a 1075 engine bike a friend has, not a concours resto just a good running weekend ride.
I have a set of 26's recently taken off my thou, they are for an A2,, full working order have a video of bike running with them on, drained, will give you more info later
Cheers Kev.
Ive got some Ribless carbs
As promised info and pics, 26mm off a Z1000 A2, so have the vacuum stub, with a bung on as mine does not have vac tap, they are the ones that came with my bike and were gummed up and had a bad repair to number one carb, what must of happened is one of the sealing balls on number one must of come out and came to me with a badly fitted grub screw and epoxy which was leaking, i removed this and cut a 5mm thread and have put a stainless countersunk screw in there sealed with ptfe tape, been fine since, they have 107.5 mains, 20 pilots, 5cn7-3 needles, pilot screws 1 and 1/4 turns out, i made brass drain screws for them, stainless allen screws on bowls and tops float levels were set wet using correct tool, then synchronized on the bench and then on the bike, i now have a set of pumpers on my bike, as these may be going on a 1075 i can change the mains for a larger size, i have 112.5, 117.5 or 122.5 if desired. they have worked fine all the time on the bike, i changed them just before lock down, i have drained them, removed the bowls and hung them up for a couple of weeks so they did not varnish up, these will be plug and play with either minor jetting changes and vac balancing. £250. posted
https://www.youtube.com/watch?v=CTeHycLbW8k
here is a you-tube video done this spring with these carbs, and a few pics.
