Z1000 A1 -Top end clean in absence of professional blaster
David32knyte
#1 PostAuthor: David32knyte » Fri Apr 03, 2020 10:22 pm
Dear Forum
Got a fairly 'Original' Z1000 A1.
Need to take top end off.
It is generally clean but remnants of silver paint from past owners attempts are v hard to shift and get at.
I was going to send to vapour blaster but they all appear closed due to the WuFlu.
I've read about rigging up a soda blaster - But again not sure soda supplies..
Does anyone have a smart way to clean the head barrels cover etc without sending them off somewhere?
Also I jet washed the engine and it's taken some chrome off the LH clutch casing ! Again some previous owners improvements.
Does anyone know how to get the chrome off as it looks crap now. Want to take it back to polished Alu.
Thanks again
D
Re: Z1000 A1 -Top end clean in absence of professional blaster
#2 PostAuthor: deka » Fri May 08, 2020 9:17 pm
Do a search for head cleaning 3m If you have chrome on your covers this would require specialist removal
#3 PostAuthor: chrisNI » Fri May 08, 2020 10:16 pm
Lollipop sticks wire wool and elbow grease :D :D
#4 PostAuthor: kev edwards » Sat May 09, 2020 6:03 am
Elbow grease with most of it, but the chrome needs a specialist touch if you want to keep parts undamaged and turned around quicker
#5 PostAuthor: Garry.L » Sat May 09, 2020 9:20 am
I'd think it would be easier/cheaper just to source another cover rather than trying to remove the Chrome from the existing.
David32knyte
#6 PostAuthor: David32knyte » Thu May 14, 2020 11:27 am
Hi All thanks for the replies.
Source another side cover.
Yes probably cheaper when you factor driving / postage etc.
I think Ill take camcover, head & barrels to TSR vapour blasting. They seem good.
Just don;t like taking the cam shells out since they seem so happy and well seated atm.
