Does anybody have a MK2 workshop manual and may have a look:
when are the front brake discs worn (min. mm)?
Z10000 MK2: front brake disc
- Sgt.Pinback
Cheers, Uli
Re: Z10000 MK2: front brake disc
I believe it is 4.5mm but I'll check for you.
- Sgt.Pinback
Thanks, would be great.
Maybe you find the mm when new as well.
Cheers, Uli
Sgt.Pinback wrote:Thanks, would be great.
5mm when new I believe
- Sgt.Pinback
Did you find the data?
Cheers, Uli
Sgt.Pinback wrote:Did you find the data?
Sorry, haven't looked but I am sure it's 5mm new and 4.5 minium
Minimum thickness is the same as the A4 discs, standard is 5.0mm & service limit is 4.5mm.
The service limit is cast into the disc carriers.
This is assuming it's a European model, it's possible the Yank versions used the thicker disc like the Yank A4's did.
