Hard to find and out of production solid rear engine mount by Debben Performance for all early Z1,Z900 and Z1000's .
AS NEW AND UNUSED .
Replaces the flimsy standard factory triangle rear mounts and multiple spacers etc with one solid unit that ties the engine to the frame resulting in increased frame rigidity under power also allows additional chain clearance when using an offset sprocket in wider rear wheel and modern 17inch wheel conversion applications.
Ideal for performance street or race use and an often overlooked item when embarking on a program of chassis improvements and bracing.
Please note that the frames original bolt holes area slack 9mm fit for the stock 8mm mounting bolts which allows the engine to shift around in stock form whereas the Debben mount uses oversize 10mm mounting bolts and three of the frames four 9mm holes will need enlarging slightly to 10mm to match and provide a secure fit that resists movement and flex.
£60 posted.
SOLD... Z1 - Z1R new solid rear motor mount,
Re: Z1 - Z1R new solid rear motor mount, Race
I'll take it, PM me your Papal details.
Re: SOLD... Z1 - Z1R new solid rear motor mount,
Buggar, if it falls through let me know, or do you have any better pics so I can make one.
Fooking hell had one of these in my hand at stafford lol
Phil
Phil
International Rep
International Rep
