Running non vacuum carbs off a vacuum tap z1000
snowyz9
#1 PostAuthor: snowyz9 » Thu Apr 18, 2019 1:58 pm
Is it ok to run non vacuum carbs , by just setting the vacuum style fuel tap to prime ?
Mark Tiller
Re: Running non vacuum carbs off a vacuum tap z1000
#2 PostAuthor: Mark Tiller » Thu Apr 18, 2019 2:21 pm
It will run fine, consider getting a Pingel tap as you will get a reserve
07962421462
snowyz9
#3 PostAuthor: snowyz9 » Thu Apr 18, 2019 2:28 pm
Thanks Mark , ps How do you get around , they seem to be single pipe feed ?
Mark Tiller
#4 PostAuthor: Mark Tiller » Thu Apr 18, 2019 2:47 pm
You can get them with a twin outlet, I think I got mine from Z1 enterprises,
07962421462
chrisw1
#5 PostAuthor: chrisw1 » Thu Apr 18, 2019 2:57 pm
The vacuum tap is opened by suction from the inlet and that is all it does , open the tap ....I do not see any reason why you could not run slide carbs on a vacuum operated tap
snowyz9
#6 PostAuthor: snowyz9 » Thu Apr 18, 2019 3:44 pm
Thanks Chris and Mark
#7 PostAuthor: zed1015 » Thu Apr 18, 2019 4:40 pm
Just run a vac pipe from one of the rubber inlet manifolds where you would normally attach the vac gauges.
It will do exactly the same job and when you want to balance the carbs just unplug the tap vac pipe from the intake boot and use prime to get the fuel feed.
#8 PostAuthor: chrisu » Sun Apr 21, 2019 12:42 pm
zed1015 wrote:Just run a vac pipe from one of the rubber inlet manifolds where you would normally attach the vac gauges.
This .
Me too on my Z1R with a mk2 tank
snowyz9
#9 PostAuthor: snowyz9 » Mon May 13, 2019 6:21 am
Well the stock tap was ok , but i changed to a single pipe pingel , as the trader said would flow easy enough , Guess what it didnt fuel starvation about 50mph
snowyz9
#10 PostAuthor: snowyz9 » Mon May 13, 2019 6:22 am
Ps are stock fuel lines 6mm
snowyz9
#11 PostAuthor: snowyz9 » Mon May 13, 2019 7:12 am
Think i have found the culprit , o ring on a drain screw breaking up , and where i filed opening in tank for pingel , i did slosh the tank out , but still can see , small powdery metal when draining carbs
