Who knows, somebody may need just these.
Marked as STD MTC 83mm pistons. Part Number on the boxes, 21-8300XC, which from what I can see means XC style rings, 83mm 00 oversize.
That would tally with the box marking.
Also each ring set is marked YWW04004AB Std. Std could mean no oversize, but I can't find any more info on that number.
New in unopened boxes, these are also going on E-bay.
£50.00 the set.
MTC Piston rings
needaz1100r
- ZedHead
MTC Piston rings
Cheers,
Mark.
Mark.
Re: MTC Piston rings
Afternoon, I'm interested in the piston rings set, 83mm is 1428cc and as I have 1428cc on my Z1B drag bike but they are cosworth pistons so would need to know a bit more info, (How thick they are? ) Better still where are you based so I could see if there compatable. Thanks .Buzzard.
Every man should have a shed (for bikes obviously..)
needaz1100r
- ZedHead
buzzard wrote:Afternoon, I'm interested in the piston rings set, 83mm is 1428cc and as I have 1428cc on my Z1B drag bike but they are cosworth pistons so would need to know a bit more info, (How thick they are? ) Better still where are you based so I could see if there compatable. Thanks .Buzzard.
Buzzard, it's Mark, I came to see you with the GSXR carbs a few weeks back. I've got a couple of cylinder heads for you to do, so I'll be coming to see you soon, but I'll mic the rings up later.
Cheers,
Mark.
Mark.
needaz1100r
- ZedHead
Rings are 0.98mm, 1.19mm and the oil control rings and expander together are 2.76mm.
Cheers,
Mark.
Mark.
Thanks Mark, hope your doing ok? Give me a call when you want to sort out the cylinder heads. Buzzard.
needaz1100r
- ZedHead
buzzard wrote:Thanks Mark, hope your doing ok? Give me a call when you want to sort out the cylinder heads. Buzzard.
Waiting for it to be warm enough to touch the engines without my frozen fingers sticking to them!
Cheers,
Mark.
Mark.
