Gpz1100b1 comparable coils
MrC
#1 PostAuthor: MrC » Thu Nov 01, 2018 6:50 pm
I'm looking for a set of coils to fit my Gpz11 .. anyone ..
8 Valve Mark
Re: Gpz1100b1 comparable coils
#2 PostAuthor: 8 Valve Mark » Fri Nov 02, 2018 10:09 pm
hi mrC, what's the issue? eg no coils on a project bike? or faulty coils? upgrades available? etc..its best to outline as much background as possible really, that way more fellow members will probably identify n try to help. oh and welcome aboard too. if it's standard coils you're looking for, i have some kicking about.. cheers mark..
MrC
#3 PostAuthor: MrC » Sat Nov 03, 2018 8:35 am
Hi the terminals have badly corroded so I'm just looking options . After market would be fine also. Thanks for the Welcome .
8 Valve Mark
#4 PostAuthor: 8 Valve Mark » Sat Nov 03, 2018 11:12 am
I'll fish around this afternoon and let you know..
#5 PostAuthor: Philippe » Sun Nov 04, 2018 5:35 am
Hi MrC
the coils are the same on a lot of bikes from that period who have an electronic ignition: Z1000J,Z1000P, and a lot more.
Take a look at CMSNL , if you know what to look for it becomes easier.
There are numbers on those coils, when searching for replacements on a scrapyard, note them down on a piece of paper and go for it. You'll certainly find replacements.
If you're lucky the HT leads can be changed, a really easy job.
You state that the terminals are corroded, clean them up, easy to do. As long as the plastic of the coils isn't cracked they'll work and give sparks.
Good luck
Gus
#6 PostAuthor: Gus » Sun Nov 04, 2018 11:32 am
According to partzilla
Right hand #1#4
This Kawasaki 21121-1038 COIL-IGNITION fits the following models and components:
Kawasaki Motorcycle 1983 Police 1000 - KZ1000-P2 Ignition
Kawasaki Motorcycle 1983 Shaft - KZ1100-A3 Ignition
Kawasaki Motorcycle 1983 Spectre - KZ1100-D2 Ignition
Kawasaki Motorcycle 1983 LTD Shaft - KZ1100-L1 Ignition
Kawasaki Motorcycle 1984 GPz - ZX1100-A2 Ignition
Kawasaki Motorcycle 1983 GPz - ZX1100-A1 Ignition
Kawasaki Motorcycle 1983 KZ1000-J3 Ignition
Kawasaki Motorcycle 1981 Shaft - KZ1100-A1 Ignition
Kawasaki Motorcycle 1982 CSR - KZ1000-M2 Ignition
Kawasaki Motorcycle 1982 GPz - KZ1100-B2 Ignition
Kawasaki Motorcycle 1982 Police 1000 - KZ1000-P1 Ignition
Kawasaki Motorcycle 1982 Shaft - KZ1100-A2 Ignition
Kawasaki Motorcycle 1982 Spectre - KZ1100-D1 Ignition
Kawasaki Motorcycle 1982 LTD - KZ1000-K2 Ignition
Kawasaki Motorcycle 1982 KZ1000-J2 Ignition
Kawasaki Motorcycle 1981 LTD - KZ1000-K1 Ignition
Kawasaki Motorcycle 1981 KZ1000-J1 Ignition
Kawasaki Motorcycle 1981 GPz - KZ1100-B1 Ignition
Kawasaki Motorcycle 1981 CSR - KZ1000-M1 Ignition
Kawasaki Motorcycle 1986 Police 1000 - KZ1000-P5 Ignition
Kawasaki Motorcycle 1985 Police 1000 - KZ1000-P4 Ignition
Kawasaki Motorcycle 1985 LTD Shaft - ZN1100-B2 Ignition
Kawasaki Motorcycle 1984 Police 1000 - KZ1000-P3 Ignition
Kawasaki Motorcycle 1984 LTD Shaft - ZN1100-B1 Ignition
Kawasaki Motorcycle 1987 Police 1000 - KZ1000-P6 IGNITION COIL
Kawasaki Motorcycle 1988 Police 1000 - KZ1000-P7 IGNITION COIL
Kawasaki Motorcycle 1989 Police 1000 - KZ1000-P8 IGNITION COIL
Kawasaki Motorcycle 1990 Police 1000 - KZ1000-P9 IGNITION COIL
Kawasaki Motorcycle 1998 Police 1000 - KZ1000-P17 Ignition System
Kawasaki Motorcycle 2000 Police 1000 - KZ1000-P19 Ignition System
Kawasaki Motorcycle 1999 Police 1000 - KZ1000-P18 Ignition System
Kawasaki Motorcycle 1996 Police 1000 - KZ1000-P15 Ignition System
Kawasaki Motorcycle 1995 Police 1000 - KZ1000-P14 Ignition System
Kawasaki Motorcycle 1997 Police 1000 - KZ1000-P16 Ignition System
Kawasaki Motorcycle 1994 Police 1000 - KZ1000-P13 Ignition System
Kawasaki Motorcycle 1993 Police 1000 - KZ1000-P12 Ignition System
Kawasaki Motorcycle 1992 Police 1000 - KZ1000-P11 Ignition System
Kawasaki Motorcycle 1991 Police 1000 - KZ1000-P10 Ignition System
Left hand #2#3
This Kawasaki 21121-1039 COIL-IGNITION,#2#3 fits the following models and components:
Kawasaki Motorcycle 1982 Eddie Lawson Replica - KZ1000-R1 Ignition
Kawasaki Motorcycle 1983 Eddie Lawson Replica - KZ1000-R2 Ignition
"Set the GRINDER on it"
