Z1000 MK2 Inner Sprocket cover
rpeters
Bristol's "H" Hoarder
#1 PostAuthor: rpeters » Wed Oct 24, 2018 5:55 am
Need a MK2 inner sprocket cover if anyone has one hiding in th egarage.
Not sure if other Z1000 will fit also?
Rob
paid up member
rpeters
Re: Z1000 MK2 Inner Sprocket cover
#2 PostAuthor: rpeters » Tue Nov 13, 2018 6:49 am
Still looking chaps, no luck so far!
paid up member
#3 PostAuthor: Philippe » Wed Nov 14, 2018 4:26 am
Hi Rob
I looked it up in the parts manual, they have the same parts number(14025-1106) so you might expect that a Z1000A1/A2 inner sprocket cover will fit on a Z1000A3 or A4 engine. Take a look for yourself at CMS.nl .
Good luck with the search.
gpjes
#4 PostAuthor: gpjes » Wed Nov 14, 2018 8:35 pm
Two wheel Spares (D&K) I've looked at converting my shaftie motor to chain & mines an E2
More Smiles Per Mile
000zeds
#5 PostAuthor: 000zeds » Wed Nov 14, 2018 8:39 pm
Try John Browse MC Spares 01978 355556
Zeds-R-Us
engz1b
#6 PostAuthor: engz1b » Wed Nov 14, 2018 8:58 pm
try z power, they list them for 900-1000
Mick J
#7 PostAuthor: Mick J » Thu Nov 15, 2018 7:25 pm
Hi Guys, the later ones are definitely different, so early ones won't fit. I was reliably informed by knowledgeable club members when looking at converting an ST to chain drive and I have compared the inner sprocket cover from an early engine to the bevel box off the ST and some of the holes line up, but not all, I was advised to use earlier crankcases as the inner cover you are looking for are much rarer. I have had some very good parts from the USA via ebay, you just have to factor in shipping and duty, but often cheaper than Uk prices, cheers, Mick
rpeters
#8 PostAuthor: rpeters » Mon Nov 19, 2018 1:53 pm
John Browse to the rescue
paid up member
