1100R 75mm PISTON
z1000puddin
1100R 75mm PISTON
#1 PostAuthor: z1000puddin » Mon Oct 22, 2018 9:30 am
Guys,
Long Shot I know, but does anyone out there have a spare 75mm piston 1170cc ( 18mm wrist pin) for my sick 1100r ?
Base gasket has turned to basically mush, & block has dropped, causing a partial seizure.
Zed til Dead
rickm
Re: 1100R 75mm PISTON
#2 PostAuthor: rickm » Mon Oct 22, 2018 9:59 am
Sorry can't help, but all of that has been caused by a dodgy base gasket?
What does the cylinder bore look like?
H2B GPZ900R
KWACKERZ1
#3 PostAuthor: KWACKERZ1 » Mon Oct 22, 2018 10:35 am
Eastwood racing can supply individual pistons if they are wisecos.
However check the valve cutouts on the replacements.
The recent sets of Wiseco piston valve cutouts are to high on the exhaust side.
Wiseco know about the issue but have not withdrawn the faulty batch.
z1000puddin
#4 PostAuthor: z1000puddin » Mon Oct 22, 2018 11:17 am
Many thanks guys,
Eastwoods are closed on a Monday, Suzuki performance also sell single pistons.
I will check the valve cut outs - thanks
Base gasket has dissolved for want of a better word, causing the block to drop, I was luck it didnt cause any more damage as it was around 110mph :shock:
Zed til Dead
Robw
#5 PostAuthor: Robw » Mon Oct 22, 2018 11:27 am
Chris Tombleson at Grumpy 1260 may have them in stock.
Rob
rickm
#6 PostAuthor: rickm » Mon Oct 22, 2018 11:46 am
KWACKERZ1 wrote:Eastwood racing can supply individual pistons if they are wisecos.
Not defending Wiseco, as any faulty batch should be recalled, but maybe it's only a problem with high-lift cams?
Plus, would that one piston not be heavier than the others if it had more metal on the crown?
Might that unsettle the overall balance?
H2B GPZ900R
#7 PostAuthor: ZedHead » Mon Oct 22, 2018 11:54 am
Stu, I can get single Wiseco if that helps
KWACKERZ1
#8 PostAuthor: KWACKERZ1 » Mon Oct 22, 2018 7:54 pm
Re the Wiseco's It may only be a problem with High lift cams and big valves, but its definitely worth checking its literally a couple of mm higher so the lip can be skimmed and reshaped easily with a dremel.
Its always a good idea to match your piston weights anyway especially if your fitting an odd one.
