Carb queery
Carb queery
Hi , I was swapping my carbs over from a pair of Rx 1000 and noticed that there was 1 petrol pipe feed down to the back of the carbs and this pipe fed all 4 carbs via a t piece between 2 and 3 and feeding the 1 + 4 carb along the same route the 2 nd petrol pipe went to the 2 nd carb where the rubber bung fits 1,3 and 4 carbs on the top where I thought the vacuum gauges would go ; now there are two t pieces for a fuel line between 1+2 and 3+4 these are not use but there not blocked off or used , should they be blocked off ?why are ther 3 places for fuel to go ? Should they let air in ? Should they face up or down ? I’m confused !!
Re: Carb queery
Really need pics as your explanation is a bit confusing regarding all the 'T' pieces and the actual bike you have RX1000 ?? but the pipe to the 2nd carb inlet rubber is for vacuum a fuel tap and the two open tee's should be carb breathers which would normally just have open pipes attached that would route somewhere around or over the airbox..
Re: Carb queery
That description is a bit confusing, but reading it I was thinking much the same.
There is ONE fuel feed which is in the centre of the bank of carbs. It should be a larger feed.
There are two breather feeds, one each between 1and2 and 3and4. they just vent to air, or into the airbox as you wish.
The last feed is the vacuum tap take off which connects to the tap.
Re: Carb queery
Sorry about the poor wording oh the question .the answer you gave makes sense that the two ports between carbs 1+2and3+4 are air vents .you could easily think that was where a petrol pipe could go !
