Stick coils
Swirl
Stick coils
#1 PostAuthor: Swirl » Wed Jul 18, 2018 1:00 pm
Anyone used stick coils on there z900/1000, it's a chop/bobber with 1045 motor, trying to get rid of the coils
Re: Stick coils
#2 PostAuthor: Ultim8pc » Wed Jul 18, 2018 1:34 pm
I don't think it would look very attractive though, stick coils are quite big and designed to be hidden down a spark plug well, not on show.
Swirl
Re: Stick coils
#3 PostAuthor: Swirl » Wed Jul 18, 2018 4:00 pm
Ultim8pc wrote:I don't think it would look very attractive though, stick coils are quite big and designed to be hidden down a spark plug well, not on show.
Yes I agree, but there are some shorter versions, I believe,
walshyco
Re: Stick coils
#4 PostAuthor: walshyco » Thu Jul 19, 2018 8:15 pm
You’re not getting rid of the coils you’re just moving them nearer to the plugs. You’re just getting rid of the leads.
Swirl
Re: Stick coils
#5 PostAuthor: Swirl » Thu Jul 19, 2018 10:01 pm
walshyco wrote:You’re not getting rid of the coils you’re just moving them nearer to the plugs. You’re just getting rid of the leads.
Sorry I should of explained more, the coils at the moment are under the seat, I want to move the coils to shorten the leads, if there where some asteticly pleasing stick coils that would be great, if not, I will have to make space under the tank/headstock area, is it that bad of a question? ???
Charlie
Re: Stick coils
#6 PostAuthor: Charlie » Fri Jul 20, 2018 8:14 am
Most stick coils are designed to run in conjunction with electronic ignition. They depend on the current supplied to fire them correctly and the resistance is usually different to the Z OE coils. You could fit them on stock ignition, but even with aftermarket stuff you'd need to check the parameters will work.
I have seen examples where even correctly wired, stick coils would not spark the plugs on non OE systems. Some need an ignition amplifier to power them. A Google search will return you most of what you need to know ;)
Swirl
Re: Stick coils
#7 PostAuthor: Swirl » Sun Jul 22, 2018 5:56 pm
Thanks Charlie
