swap for Beer tokens !
Gpz1100 1000j Sidestand
Gpz1100 1000j Sidestand Any one got one spare they want to part with.
Re: Gpz1100 1000j Sidestand
You're probably already aware of this but often the ones advertised for 1000j are not the same as the original ones that came on UK bikes. The US versions (which I'm currently stuck with) only have one spring, and seem to be a bit shorter, making the bike lean over a lot when on the side stand.
H2B GPZ900R
Rick Thanks for that I was not aware but dont mind either really as long as it fits the bracket.
Cheers for the warning though.
- paul doran
I believe I have a UK model stand some where be tomorrow before I get to look
Cheers Paul.
Don't bust a gut though I think I may go down a modified zx6r route so I can bolt it on and off.
But if you have one that could be my backup.
Phil
Phil
Phil - if you decide that you don't want it, then I would be interested.
Rick
Rick
H2B GPZ900R
Rick, I'll let you know as I have not tried the modified route yet as its not arrived yet. It may be a no go but I' will post and let you know.
Anyway knowing how much stuff Paul has stashed away it could take him a month of sundays to find it
eh Paul!
- paul doran
hopefully not but it will be Saturday before the search begins
Paul, Rick, my zx6r stand arrived today and after a bit of fab work looks like it will be ok.
So if you want to sort out the stand between you I am fine with that.
Paul thanks for the offer though.
Phil
Phil
- paul doran
I have found that stand it has two spring mounting brackets
