Z900/Z1000 alternator rotor
Mick J
#1 PostAuthor: Mick J » Mon Jan 01, 2018 11:47 am
Hi Guys, has anyone got a spare alternator rotor, woodruff key type, for a z900 or z1000? I also need the starter clutch and idler gear, inner points housing, inner sprocket cover, gearbox output shaft, gearchange shaft (the one with the splines that the lever fits on) and I need a pair of 30 tooth cam sprockets. I'm using a z900 bottom end with a z1000st top end. The clutch is there and I have an alternator cover but all other ancillaries have been removed, so anything you may have could be useful to me. Cheers, and a happy new year to all, Mick
Re: Z900/Z1000 alternator rotor
#2 PostAuthor: paul doran » Mon Jan 01, 2018 12:03 pm
I have a rotor plus gearbox bits and inner covers
