900A4 carb bowls removal
ddg900
#1 PostAuthor: ddg900 » Sun Feb 12, 2017 5:34 pm
hi all,
I'm blessed (!) with small hands/fingers. My 900A4 could do with the float bowl gaskets on cyls 1 and 2 being replaced (persistent fuel weep despite attempts to check tightness of screws with a 90deg angled screwdriver - not a brilliant fit).
Is it possible to do this with the carbs in-situ? Anybody have knowledge of a screwdriver small enough to do the task?
thanks
KAWASAKI KZ900A4
SUZUKI GT250M
H**** CB250G5
H**** CB360G5
harri183
#2 PostAuthor: harri183 » Sun Feb 12, 2017 5:48 pm
I would take carbs of otherwise you may end up stripping the heads will work out quicker in the long run.
PAULJAC47
#3 PostAuthor: PAULJAC47 » Sun Feb 12, 2017 6:38 pm
Its easy, i use a very small phillips with a hole drilled and a tommy bar through,or a phillips and small socket wrench,put a towel under neath to catch screws,fuel etc.if leaking though you may well have float level issue.Paul J
Steve Cooke
#4 PostAuthor: Steve Cooke » Sun Feb 12, 2017 6:40 pm
Ideally carbs off as said, you need to clean /check the mating faces which is just about impossible to do insitu.
bunnysZ
Granny Magnet
#5 PostAuthor: bunnysZ » Mon Feb 13, 2017 6:27 am
swampy
#6 PostAuthor: swampy » Mon Feb 13, 2017 6:43 am
Take them off, clean em check needle valves, set float heights and replace all the gaskets because it wont be long before all four start weeping otherwise,
PAULJAC47
#7 PostAuthor: PAULJAC47 » Mon Feb 13, 2017 5:48 pm
Thats the same as one is use as well...
ddg900
#8 PostAuthor: ddg900 » Thu Feb 16, 2017 11:05 pm
thanks guys - prob going to go for taking them off the bike and doing the full set, inc float heights. The little ratchet driver looks good - might get that anyway :wink:
KAWASAKI KZ900A4
SUZUKI GT250M
H**** CB250G5
H**** CB360G5
8 Valve Mark
carbs
#9 PostAuthor: 8 Valve Mark » Fri Feb 17, 2017 1:15 am
a wee smidge of grease or oil on your float bowl gaskets b4 re-assembly always works for me[/b]
PAULJAC47
#10 PostAuthor: PAULJAC47 » Fri Feb 17, 2017 9:49 am
Always a ball ache getting carbs off,on makes it easier if all intake and airbox rubbers supple,take off the starter cover,and the brace across carb tops to get cables off easier,when putting back on only fit centre two airbox rubbers then roll back outer two on them selves and use smooth tyre iron to lever into airbox.
ddg900
#11 PostAuthor: ddg900 » Sat Feb 18, 2017 10:34 pm
got the little ratchet set today - worked a treat. One loose screw, gave it a tweak, seems to have worked. Good point about the float heights, and I will get round to checking them. Had the fuel pipes off today - noticed that there's a weep from the fuel tap when switched to 'OFF' - looks like the tap's going to need an overhaul as well .. :roll:
That can all wait for the next wet weekend - forecast is too good for tomorrow not to take her out for a quick spin :D
KAWASAKI KZ900A4
SUZUKI GT250M
H**** CB250G5
H**** CB360G5
bunnysZ
Granny Magnet
#12 PostAuthor: bunnysZ » Sun Feb 19, 2017 7:22 am
its a good tool , but I do find allen heads are better ast they are stronger and you can tighten them up more. you can still remove them in situ if needed as well then
ddg900
#13 PostAuthor: ddg900 » Mon Feb 20, 2017 9:37 pm
good point, bunny..
I'm not such a rivet-counter that swapping to Allen heads would give me sleepless nights :lol: - far better the bike runs sweetly, and I can attend to those little things that always need doing, with the minimum of fuss.
think I'll look for a replacement carb bowls Allen screw set for the 900A4 next time I get a weeping gasket - its bound to happen again at some point!
KAWASAKI KZ900A4
SUZUKI GT250M
H**** CB250G5
H**** CB360G5
