Hi all
I need some advice on the best way to highlight the labelling on the switch gear of my a4.
all help gratefully received.
handle bar switch highlighting
- warren3200gt
Use enamel hobby type tins of humbrol. Paint them all white regardless of if they were red/yellow originally. Get a tissue that is damp with enamel thinners and lightly wipe over the painted letters. This needs to be done before the white is dry. It'll take off any of the white paint that is outside the letter recess's leaving the black surround intact.
When dry, do the same again using yellow on the yellow letters and red on the red letters. The underlying white will make the over lying yellow or red colours much brighter and they'll stand out much, much better.
Literally takes 30 seconds to do each set, bar the drying time. Saves hours of faffing with cocktail sticks etc.
wilsonsjw11
Thanks chaps
I used pretty much all of the advice and ended up with this end result.
[img][img]http://i1244.photobucket.com/albums/gg574/paulkemp2/Mobile%20Uploads/20161120_212751_zpsinbxdpeq.jpg[/img][/img]
