uk master cylinder
harri183
uk master cylinder
#1 PostAuthor: harri183 » Fri Sep 09, 2016 10:04 am
Does the plastic bit of the uk Z1 master cylinder come out, sending it to get anodized. Cant see anything holing it in but will it hell as shift.
z2.john
#2 PostAuthor: z2.john » Fri Sep 09, 2016 11:56 am
They sure do but can be a bitch to remove. You need one of those leather ratchet straps so as not to damage the plastic. It is a standard RH thread just in case you're wondering.
Make sure you don't lose the very thin rubber washer/ seal.
Good luck. Some are easier than others
John
#3 PostAuthor: z1bman » Fri Sep 09, 2016 1:38 pm
soak it in hot water
tlc
#4 PostAuthor: tlc » Fri Sep 09, 2016 1:53 pm
Harri.
There is a plastic base in the bottom. Use a right angled pick to pull upwards through one of the spaces and it will come out.
Under that are 2 screws which when undone will allow the plastic tube to be pulled out.
When you are ready for a new o ring let me know as I can supply you one foc
harri183
#5 PostAuthor: harri183 » Fri Sep 09, 2016 2:17 pm
Don't think that's a Z1 master cylinder TLC, there is no screws holding the plastic part to the metal master cylinder and the plastic part on mine has no bottom (like a polo mint). Cheers
z2.john
#6 PostAuthor: z2.john » Fri Sep 09, 2016 2:39 pm
Z1 models have a screw in plastic piece.
Not seen TLC's so can only assume that is for Z900 Z1000 maybe?
harri183
#7 PostAuthor: harri183 » Fri Sep 09, 2016 4:41 pm
Can anyone recommend a set of long nose circlip pliers that will remove the piston circlip, something that is right length and small enough to get in. Cheers
#8 PostAuthor: z1bman » Fri Sep 09, 2016 5:39 pm
harri183
#9 PostAuthor: harri183 » Fri Sep 09, 2016 6:20 pm
Cheers.
tlc
#10 PostAuthor: tlc » Fri Sep 09, 2016 7:28 pm
Whoops.
Got so excited I didn't see it was the inferior Z1 model.
harri183
#11 PostAuthor: harri183 » Thu Sep 15, 2016 12:19 pm
Any advice on the removal of the piston, do you have to de-press the piston to get at the circlip?
Thanks for the advice
#12 PostAuthor: z1bman » Thu Sep 15, 2016 12:29 pm
you have a spring clip which secures the rubber gaiter which can be removed with a small electrical screwdriver then you have the cir clip which secures the piston & there is no need to depress the piston
wilsonsjw11
#13 PostAuthor: wilsonsjw11 » Thu Sep 15, 2016 12:30 pm
tlc wrote:Whoops.
:smak
DavidZ1R
#14 PostAuthor: DavidZ1R » Thu Sep 15, 2016 2:27 pm
z1bman wrote:you have a spring clip which secures the rubber gaiter which can be removed with a small electrical screwdriver then you have the cir clip which secures the piston & there is no need to depress the piston
Did just this today, needed a long thing circlip remover, and yes I had to depress the plunger to get the remover arms in, but did it. Bitch of a job
