Drill and tap jig for exhaust studs
Zomerset Zed
#1 PostAuthor: Zomerset Zed » Thu Dec 31, 2015 3:28 pm
Does anyone have a drill jig so you can re-drill and tap the exhaust stud threads and get them in correct location and parallel to other studs :?:
I would be surprised if no-one has ever made something up to this effect :o
Jumbo
#2 PostAuthor: Jumbo » Thu Dec 31, 2015 4:01 pm
If you search on Google Images for "exhaust stud jig" there are plenty. I snapped all the exhaust studs on my BMW and made a small jig that screwed onto the remaining part of the stud and successfully drilled and tapped them. Which ever way you do it it is not that easy !
LE to JOG on a z900
P.U.M.
#3 PostAuthor: Ginger Bear » Thu Dec 31, 2015 4:47 pm
Bowden auto engineering in Filton will spark erode 'em for you if you want an easy life.
#4 PostAuthor: ZedHead » Fri Jan 01, 2016 2:52 pm
Someone made one on here cant remember who
Zomerset Zed
#5 PostAuthor: Zomerset Zed » Fri Jan 01, 2016 4:11 pm
just did that and a lot of them look unsurprisingly like the one i have designed:
Big boss fits into exhaust port and seats on gasket face. Plate is welded to boss. Small hole is for location on existing stud, and other end has a screw in drill or tap guide. This is the tap guide in place and will support the tap over its full length.
Will probably make this and then others can borrow in future :)
