Z1 Front Hub Seal
wheelysteve
Z1 Front Hub Seal
#1 PostAuthor: wheelysteve » Tue Jun 30, 2015 8:06 am
Anyone got a new front hub seal (speedo drive side). Part no. 92050-046.
Front brake not working too well as the disc is being sprayed with grease on a long run. Stops the brake squeaking though !!
Is there any special grease required for the speedo drive or is the standard castrol stuff ok as I seem to have it coming out of the seal and speedo cable fitting a the wheel end since I cleaned and re greased it?
Cheers Steve
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Jumbo
#2 PostAuthor: Jumbo » Tue Jun 30, 2015 7:37 pm
This is only an oil seal. I just ordered one from Ebay. If you are not sure of the sizes I can check what I bought.
LE to JOG on a z900
P.U.M.
wheelysteve
#3 PostAuthor: wheelysteve » Tue Jun 30, 2015 7:58 pm
Cheers Jumbo, I would appreciate the dimensions.
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
wheelysteve
#4 PostAuthor: wheelysteve » Thu Jul 02, 2015 2:01 pm
The markings on the seal show:
BJN-C2 54 65 6
Which I take to mean it's a 54mm internal dia, 65mm external dia and 6mm seat width. I can't find this size listed in the searches I've done. Is it a one off size for the Z ?
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Coose
#5 PostAuthor: Coose » Thu Jul 02, 2015 2:43 pm
wheelysteve
#6 PostAuthor: wheelysteve » Thu Jul 02, 2015 5:19 pm
That's the one , but he is away till 14th July and I was hoping to get it in the next couple of days. Guess i'll have to wait until Dave is back. (UKS1).
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Jumbo
#7 PostAuthor: Jumbo » Thu Jul 02, 2015 5:47 pm
Apologies I misunderstood the seal. I thought it to be the seal inside the hub. Also I have an A4 which looking on CMSL was a different part number even for that seal. Mine was 17x23x3mm Nitrile Rubber Metric Oil Seal.
I looked on Simply Bearings Website and your seal does not appear to be a common size.
LE to JOG on a z900
P.U.M.
