AP Lockheed CP2696-110C Calipers
#1 PostAuthor: ADRIAN H » Mon Mar 30, 2015 7:22 pm
Does anyone know of a company that stocks Brake pistons & caliper repair kits for AP Lockheed CP2696-110C Calipers.
Note these 1980's original Lockheed calipers, Not the AP Racing CP2696. Pistons are slightly smaller.
Thanks in advance.
Adrian
Big Fluff
#2 PostAuthor: Big Fluff » Tue Mar 31, 2015 12:41 pm
Adrian.
Try here https://www.pegasusautoracing.com/keywo ... dButton=Go
I've used them a few times for parts for the Silver Saxon.
Also.... http://www.norvilmotorcycle.co.uk/
They have the following:
CP2055 PISTON - CALIPER - DEEP - TO FIT 063930 - NORVIL £18.69
61896 PISTON - CALIPER - FOR STANDARD CALIPER - CHROME £16.00
061896SS PISTON - CALIPER - FOR STANDARD CALIPER - STAINLESS STEEL £17.18
CP2195 PISTON - CALIPER - SHALLOW - TO FIT 063930 - NORVIL £18.69
CP2410102 PISTON - MASTER CYLINDER - 0.7" DIAMETER - FOR TWIN DISC £24.05
61898 PISTON - MASTER CYLINDER - FRONT - FITS ALL DISC BRAKES £11.67
999930SS PISTON - MASTER CYLINDER - REAR - MK3 ELECTRIC START - STAINLESS STEEL Call
Also, on eBay http://www.ebay.co.uk/itm/151629778883?rmvSB=true
Regs, Will
Hobbo
International Rep
yo
#3 PostAuthor: Hobbo » Tue Mar 31, 2015 3:59 pm
Adrian
Just got all my parts for cp2696 Lockheed from seals ect from Dave Trollope Racing they supply all you need fair prices as well . Also sell on ebay DTR
400871866445
PHIL
International Rep
martinz1000r
#4 PostAuthor: martinz1000r » Tue Mar 31, 2015 4:26 pm
I 2nd DTR. Also try Andover Norton. If DTR dont have them Andover Norton will.
#5 PostAuthor: ADRIAN H » Tue Mar 31, 2015 4:41 pm
Thanks for the response.
I spoke to Andover Norton this morning and they said these particular calipers were standard fit on Triumph Bonneville T140V 1980 - 1983. However they have not got the correct parts. But with a bit of luck I should be able to find the parts I require.
I will take them out tonight and measure them as apparently there are two different depths they could be. I will phone around tomorrow they companies mentioned above, fingers crossed.
Thanks again. Adrian.
Hobbo
International Rep
yo
#6 PostAuthor: Hobbo » Tue Mar 31, 2015 5:00 pm
Adrian
DTR Have the pistons you need on ebay item no number
400890959833
PHIL
International Rep
Re: yo
#7 PostAuthor: ADRIAN H » Tue Mar 31, 2015 6:42 pm
Hobbo wrote:Adrian
400890959833
PHIL
thanks. Adrian.
I have just measured the brake pistons and they are 41.3mm diameter 1 no 20mm deep, other 17mm deep. Same as AP Racing CP2696 - happy days.
:D
