I have searched the forum but cannot find any info on stripping the front forks on. my bros 74 z1a
Can anyone point me at a tutorial or a how to?
The problem is we need to remove the stansions but when the bottom bolt is loosened the damper rod is turning and i cannot find a way to restrain it whilst removing the bolt.
I have tried gripping the top of the rod by dropping a couple of extensions with a gorrila socket on but the rod still appears to be turning.
I thought i may be able to lock the rod by screwing a long bolt into the drain hole but that doesn't appear to work either.
Any info gladly accepted thanks in advance.
front forks dismantle
keith mayall
I got them out but the end of the damper tube is a round solid end so the insert idea won't work,
the whole lot still spun round with the windy gun solution,
so i resorted to the 15mm copper pipe i flattened the end and jammed it in the gap at the side of the round tube end and it stopped the tube turning while the bolts were removed.
so job done and thanks for the help.
Alan100 wrote:I got them out but the end of the damper tube is a round solid end so the insert idea won't work,
While there apart knock up a rig to stop the assembly turning when you put the forks back together.
Z1000 MK2
Z1300 DFI
Z1300 DFI
