From studying the wiring diagrams (I have 2 and am not sure which one I need
If I turn the ignition to 'park' the light comes on, so the wiring to the rear light and earthing is ok. Is it normally wired direct?
I seem to have new switchgear with the Z1 wiring, blue power wires to the lights, and A4 for the rest of the loom. The bright blue (see how new they look) wires coming out from the switchgear looms, are wired like this - this is a pic from the stripdown.
The one close to the coil is the one to the dip switch, and the one with the large connector is the live feed from the light switch (it is live with the ignition and light switch on). The smaller one goes to a blue wire of a different shade (an old wire) and the larger one goes to a blue and white wire, also an older one. The A4 wiring diagram shows a blue/white wire going to the fuse box, then back as a blue wire. These are probably the wires in question but then why doesn't it work? Yes the fuse is ok
I can just join the bright blue wires together, and the headlight works, but I still have no rear light.
The A4 wiring diagram has something that looks like a fuse just before switch but I can't find it anywhere on the bike, and cannot actually read what this thing actually is as the wording is very blurry.
Any ideas?
Richard
