Most of the images showed the images showed the calipers in front of the forks, so why are mine behind them?
freddyz1r wrote:IMO richard, the solid metal pipes (similar to the link below),look better if the caliper is on the front of the legs. The flexible braided hoses don't seem to sit/fit/look right if on the front. Just my opinion, might be worth a look.
http://www.saisei-europe.com/Shop/Produ ... pipe-z1-rh
Cheerz freddy
Pigford wrote:Main reason is to speed up steering as there is less effect from the mass of the calipers when they're at the rear of the legs, rather than on top
coldsummer wrote:Pigford wrote:Main reason is to speed up steering as there is less effect from the mass of the calipers when they're at the rear of the legs, rather than on top
The other rumour doing the rounds back in the day was that there was less fork dive on heavy braking but I don't know about that, probably had no noticeable affect?
