Best size Carbs?
Best size Carbs?
Looking at a new set of Keihin CR carbs for my Z900.
Are 29's best suited to standard bore 900 or would you go something slightly larger?
Thanks.
Thanks.
Any larger than 29mm runs the risk of over fueling standard Z900 head.
The Keihin CR special's CAN be difficult to dial in spot on as it is,
without extensive dyno runs, however, an experienced
race techy would set them up a doddle, compared to the average novice (like me).
They are simpler to work on than the standard Z900 26mm Mikuni's
though, especially setting the needle heights!
~Jay.
~Jay.
- Ginger Bear
martinz1000r
you will need a twin cable push/pull type throttle. I ran CR29 on my 1260 Z900 at Cadwell last year and it ran out of steam at the top end so now running CR33.
I've just ordered a set of CR29's from Dynoman in the US, the owner Buzz was very helpful, I've also ordered spare jets, one size smaller & one size larger.
http://www.dynoman.net/carb/keiCR.html#cr29s
Hope they arrive before Christmas
73 Z1, HondaCRF 450
Most of my money has been spent on Z's, beer & women,
The rest has been squandered.
510racer wrote:Thanks for that Jay.
Sounds like you've had experience with both, so could you please tell me one more thing: Do the Keihin's run the same push/pull throttle cable linkage?
Yes, like chrisNI was saying,
just hook up push/pull throttle cables like you
would on your standard carbs. I bought CR 29's for my Zed
from Allens Performance, and straight out the box already had the linkage fitted for the standard throttle cables.
~Jay.
Had a set of Cr 29's on my standard 900 after a needle change as was running a bit weak ran a treat!! you will need a push/pull throttle I use motion pro basic but work well. Allens performance good guys!!
Ducati 1199R Race
Ducati 1198R Race
Suzuki GS/GSXR1216 Turbo Drag
Suzuki Katana 1170 Homa sz
Yamaha R7/R1 motor
Kawasaki ZXR750R M1
KTM SXF250
The older it gets the faster it was :-))
Ducati 1198R Race
Yamaha R7/R1 motor
Kawasaki ZXR750R M1
KTM SXF250
snotie1965
Hi martin, have you still got your old 29`s ? if so ,do you think they would be suitable for my uni-trak with 1170 wiseco ? or should i go bigger ?martinz1000r wrote:you will need a twin cable push/pull type throttle. I ran CR29 on my 1260 Z900 at Cadwell last year and it ran out of steam at the top end so now running CR33.
- london calling
I have rs 36's on my Katana 1170 with head work cams they work really well loads of grunt go to big it pushes it to far up! tuned by Chris at Grumpy 1260:)
Ducati 1199R Race
Ducati 1198R Race
Yamaha R7/R1 motor
Kawasaki ZXR750R M1
KTM SXF250
Ducati 1198R Race
Yamaha R7/R1 motor
Kawasaki ZXR750R M1
KTM SXF250
