Can anyone advise on how to move the headlamp bracket sleeves at the top of the fork legs?
The reason I need to know is that the headlamp is off centre and I can see that the brackets are at different angles on the forks - (the left one is turned in and the right one is turned out), so I need to twist them both to the same position.
I assume these brackets are separate sleeves that fit around the forks and when you loosen the fork clamps, they will be able to move?
The trouble is, when I loosen the clamps, won't the forks shoot up through the headstock with the front wheel on the ground? Or is there enough friction without levering the clamps apart, to hold the fork legs in position?
Or maybe the brackets are fixed in one position and I cannot move them - they are just bent....???
Headlamp bracket chrome sleeves
Well, it didn't work!
One of the brackets could be moved, but the other one was jammed solid....even after a few whacks with a hammer !
I decided that too many whacks was not a good idea.
The bracket is possibly corroded onto the fork tube. The free one had been re-chromed about a year ago, so had obviously been removed at that time.
I might try spraying some WD40 around the stuck one to see if that helps.
You're joking right!! :confused: Mate, those fork tubes must be seriously rusted, unless some pill has glued 'em on. Be interesting to see how you get on here.
Good news guys.....
I have finally moved the offending bracket!
I had a think about it and decided to loosen both top and bottom fork clamps on the affected side and leave the other fork as it was, so as to support the front and stop the loosened fork tube from moving up in the clamps.
I thought that I could twist the entire fork leg in the clamps so that the bracket was straight.
This was not required - as soon as the bottom clamp was undone, the bracket moved!
It wasn't corroded on.
JOB DONE! Headlamp now straight.
Users browsing this forum: chrisNI and 62 guests
