floode deisel
mick znone
floode deisel
#1 PostAuthor: mick znone » Tue Feb 04, 2014 9:53 pm
just hit a flood at speed, car cut out and then wouldnt start, had to wait for aa to tow me, while waiting water came up over the cills so i had to abandon. the aa managed to tow me out after i waded in and hooked it up. they towed me back but the electrics were all failing on the way back. aa chap says write off, anyone know better :?: should i try to start it in the morning or get a garage to look at it first or just scrap it :?:
#2 PostAuthor: ZedHead » Tue Feb 04, 2014 9:59 pm
Let it dry out and try again
Redbeard
#3 PostAuthor: Redbeard » Tue Feb 04, 2014 10:04 pm
Get it checked for water ingress before starting just to be sure. A mate did the same and decided to start it, engine had to be replaced on his 3 yr old car.
mick znone
#4 PostAuthor: mick znone » Tue Feb 04, 2014 10:10 pm
yes i guess i need to phone my mate in the morning and see if he thinks its worth trying to empty it out.
#5 PostAuthor: Pigford » Tue Feb 04, 2014 10:13 pm
If water has got into the engine via the air box - that can seriously fook a diesel motor - BANG :??
If its just electrics - hair drier Mick :wink:
Redbeard
#6 PostAuthor: Redbeard » Tue Feb 04, 2014 10:14 pm
Might be worth spraying as much of the electrics it's possible to get to with WD as well. Hope it works out ok for you.
#7 PostAuthor: z1bman » Tue Feb 04, 2014 10:22 pm
what car is it ?
mick znone
#8 PostAuthor: mick znone » Tue Feb 04, 2014 10:25 pm
Peugeot 206 1.4 diesel. i definitely heard some gurgling sounds :cry:
Harry H
#9 PostAuthor: Harry H » Tue Feb 04, 2014 10:47 pm
Water does not compress if you get it in the engine and then try to start it
goodbye engine
#10 PostAuthor: z1bman » Tue Feb 04, 2014 11:07 pm
remove the heater plug's & spin the engine over for a few times with the air cleaner removed then re fit the heater plugs + try to start it. some easy start may be required if that fails chuck it in the skip
mick znone
#11 PostAuthor: mick znone » Tue Feb 04, 2014 11:13 pm
ive been told the glow plugs in this car are real b'gg'rs to get out, but i will have a look in the morning. cheers guys.
oldtimer
#12 PostAuthor: oldtimer » Tue Feb 04, 2014 11:29 pm
Glow plugs can be a real swine to remove and have habits of snapping off, my old Mercedes mechanic once told me to soak around the glow plugs with a penetrating fluid the day before attempting removal, have a quick search on google, bound to be something on there.
mick znone
#13 PostAuthor: mick znone » Wed Feb 05, 2014 9:20 am
thanks oldtimer, all advice has been gratefully recieved. :bow
#14 PostAuthor: Pigford » Wed Feb 05, 2014 10:06 am
I know for a FACT that the 306 is prone to water in engine - as the air intake is low at the front of the car :?? He got it towed to a garage and they had another couple of 306's in for similar trouble.
A mate trashed his diesel 306 couple weeks back - only going slow through a 4" puddle :roll:
Good luck Mick :!:
mick znone
#15 PostAuthor: mick znone » Wed Feb 05, 2014 10:29 am
cheers Piggy, i dont hold out a lot of hope for this one but have to give it a try. my mate is phoning me in a bit, he's the man that can with cars, if its knackered he works at a dealership and i will buy another trade in.
Return to “The Bottom Shed”
