18T 530 3/8 offset J sprocket
#1 PostAuthor: Al » Wed Jan 29, 2014 9:50 pm
Anyone got one loafing about?
#2 PostAuthor: Ginger Bear » Fri Jan 31, 2014 1:42 pm
Debben will have 'em on the shelf Al, if you get no joy here.
#3 PostAuthor: Al » Sat Feb 01, 2014 10:46 am
Thanks Steve i have spoken to Ray and none in stock now or for a while.
There is a 'weld up' option or a 5/8 option so will have to go back to the measuring tape and see what i can get in there.
#4 PostAuthor: Ginger Bear » Sat Feb 01, 2014 12:21 pm
Talon will make you one, cost for a 'one off' will probably around £65 or so. :save :save :save
#5 PostAuthor: Al » Sat Feb 01, 2014 4:06 pm
Just North of 'one large' for a 'one off' Steve.
stempy
#6 PostAuthor: stempy » Sat Feb 01, 2014 6:15 pm
Is the j the same output shaft as a z1000 ?
PUM 451
#7 PostAuthor: zed1015 » Sat Feb 01, 2014 8:37 pm
stempy wrote:Is the j the same output shaft as a z1000 ?
J onwards has larger dia output shaft, Earlier sprocket won't fit.
