Help with engine transport
Is Vic There
#1 PostAuthor: Is Vic There » Sun Jan 26, 2014 9:42 pm
Evening gang :D
As you know I have the Harris project at Harris and was originally going to fit a GPz1100 engine to it, bit of a change as the cost to carry out the modifications to fit the engine is more than the cost of a new frame!
So I need any solid mount 900/1000 engine, I was thinking of bidding on this
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 1308478649
If I won could anyone help collecting it and taking it to Harris for me?
Obviously beer tokens would be offered :wink:
Or does anyone have an engine that they want to sell?
Please can you let me know if you can help? Or does anyone know of a company that can collect the engine of take it to Harris?
Spen72
#2 PostAuthor: Spen72 » Sun Jan 26, 2014 10:12 pm
Hi I live in Hampshire. ..I could get the engine for you...where is the Harris works at?..im off work Friday so could run the zed engine up to them...is this any help?...spence
#3 PostAuthor: Al » Sun Jan 26, 2014 10:13 pm
I work in RG29 (just now untill they sack me anyway)
I can pick it up and take it home if it helps but as for Harris,.. i wont be going there anytime soon.
Do you really need to splash out on an un-known engine and then pay to export it?
Could Harris not get by with empty cases if its only the position of the mounts they need or is it more involved?
mick znone
#4 PostAuthor: mick znone » Sun Jan 26, 2014 10:28 pm
he has one feedback as a seller and you are thinking of buying an engine from him that he wont post to Australia (probably because Australia have a returns policy that he doesnt want to honour) id be careful there myself.
Is Vic There
#5 PostAuthor: Is Vic There » Mon Jan 27, 2014 3:25 am
Hi Lads,
Has anyone got or know of an engine for sale then :idea:
The only reason its going to Harris is they can put in the crate along with the engine, you pay for space more than weight when you export to Australia.
Spence, the address for Harris is
http://www.harris-performance.com/cgi-b ... N=SHOWFORM
Is Vic There
#6 PostAuthor: Is Vic There » Mon Jan 27, 2014 3:44 am
Daft question but, will a GPz1100 internals and top end fit this?
http://www.ebay.com.au/itm/kawasaki-z90 ... 2588b662bf
Is Vic There
#7 PostAuthor: Is Vic There » Mon Jan 27, 2014 4:11 am
The bloke live in a village called Odiham RG29, is this near a RAF Base?
garyd
#8 PostAuthor: garyd » Mon Jan 27, 2014 9:52 am
When is your deadline for getting it to Harris?
Spen72
#9 PostAuthor: Spen72 » Mon Jan 27, 2014 10:05 am
Hi there yes the man lives just before Farnborough off the m3..air base is near by...and harris is just past London..I could pick the engine up on the way back from work Thursday as I work in Woking. .and take it up to harris Friday lunchtime. ..spence
Is Vic There
#10 PostAuthor: Is Vic There » Mon Jan 27, 2014 10:45 am
garyd wrote:When is your deadline for getting it to Harris?
Not really in any rush Gary, they have not started on the frame yet, reckon its a good three months off from leaving Blighty.
Is Vic There
Re: Help with engine transport
#11 PostAuthor: Is Vic There » Mon Jan 27, 2014 10:47 am
Spen72 wrote:Hi there yes the man lives just before Farnborough off the m3..air base is near by...and harris is just past London..I could pick the engine up on the way back from work Thursday as I work in Woking. .and take it up to harris Friday lunchtime. ..spence
Hey Spence that would be really good, not too sure if I'm going to bid yet, must admit I'm in two minds at the moment with the previous comments.
Would prefer to buy one from someone on here!
#12 PostAuthor: zed1015 » Mon Jan 27, 2014 11:41 am
Is Vic There wrote:Daft question but, will a GPz1100 internals and top end fit this?
Easiest part to swap is the GPZ head with an APE Idler tower conversion .
The gearbox needs an output bearing conversion and modifications to fifth gear, but you will need the z9/1000 gear selector mech, drum and forks of which the drum and its 3rd gear fork also need modifying.
GPZ head has bigger combustion chamber volume so the 2 point compression drop will need addressing and the gear box swap needs careful setting up.
Crank and barrels will also fit but you need to convert the upper crankcase to take the slipper tensioner mechanism.
markz9
help with engine
#13 PostAuthor: markz9 » Mon Jan 27, 2014 11:41 am
hi did you sort out the engine i am not far from odiham and can grab it but might take a little while till i am over at harris i do know steve and lester so pop over every now and then
mark
mick znone
#14 PostAuthor: mick znone » Mon Jan 27, 2014 12:54 pm
have you asked him if you can view the engine? at that sort of money he should be cool.
Toyboy
#15 PostAuthor: Toyboy » Mon Jan 27, 2014 6:59 pm
Save your money this is what you want for the Harris
http://www.ebay.co.uk/itm/Kawasaki-1978 ... 3cdac770a6
