A4 Carb Bits
DaveZ1
A4 Carb Bits
#1 PostAuthor: DaveZ1 » Thu Jan 16, 2014 9:18 pm
Does anyone have a set of A4 carbs lying around they would like to part with a few spares from? ( for a fee of course :wink: )
I am after a couple of float bowl drain plug screws, the main throttle return spring, the thin connecting plate that is fixed by the carb top
screws and connects all 4 carbs and the little spring that sits in a recess and sits up against the throttle bracket. Any condition is fine so
long as they will re-zinc plate OK.
Or if you have a set of carbs that are knackered with these bits still on, I would be willing to buy the lot for spares.
The carb set I bought on ebay for a mates A4 resto has these missing :(
Cheers Dave.
#2 PostAuthor: z1bman » Thu Jan 16, 2014 9:32 pm
#3 PostAuthor: chrisu » Fri Jan 17, 2014 2:04 pm
£7.99 each ............. :shock:
DaveZ1
#4 PostAuthor: DaveZ1 » Fri Jan 17, 2014 4:53 pm
Just a thought Guyz......If anyone has a set of A4 carbs that they dont want to part with I would appreciate it if they could remove this connector plate (6 x M4 screws) put it on a piece of A4 paper draw around it and post it off to me, I know a very nice man who would have a number of these laser cut in the correct guage plate for me to have Zinc plated then there would be spares available for anyone that wanted one and the template doner would get a nice shiney one free!
I agree with Chrisu £7.99 per screw (Z-Power) is a bit steep also I would be looking at £14 inc shipping for the small spring :roll: . used is best methinks.
DaveZ1
#5 PostAuthor: DaveZ1 » Fri Jan 17, 2014 5:35 pm
Just so we're all on the same song sheet :wink: This is a set of A4 carbs I restored for a Z1OC member showing the bits in question.
Streetfighterkz
#6 PostAuthor: Streetfighterkz » Fri Jan 17, 2014 6:02 pm
I'm not sure if it'll be any cheaper but Suzuki p/n 13247-45010 is the same drain screw. It was used on Gs1000's. I picked up a set for my Kz1000 and they were the same as far as I could tell.
Later, Doug
#7 PostAuthor: Ginger Bear » Fri Jan 17, 2014 6:07 pm
DaveZ1 wrote:Just a thought Guyz......If anyone has a set of A4 carbs that they dont want to part with I would appreciate it if they could remove this connector plate (6 x M4 screws) put it on a piece of A4 paper draw around it and post it off to me, I know a very nice man who would have a number of these laser cut in the correct guage plate for me to have Zinc plated then there would be spares available for anyone that wanted one and the template doner would get a nice shiney one free!
Dave, I can do this for you. I've promised meself some 'garage' time this weekend. I can probably help with the springs as well, but they're well and truly buried under a mountain of stock, that won't be moving until the end of the month. :??
DaveZ1
#8 PostAuthor: DaveZ1 » Fri Jan 17, 2014 6:20 pm
Nice one GB :D :D time is not an issue my friend, whenever your ready.
Cheers, Dave
DaveZ1
#9 PostAuthor: DaveZ1 » Fri Jan 17, 2014 6:30 pm
Great info Doug thanks
#10 PostAuthor: Ginger Bear » Sun Jan 19, 2014 5:41 pm
Dave, pm me your addy & I'll get this bracket outline off to you. :wink:
DaveZ1
#11 PostAuthor: DaveZ1 » Sun Jan 19, 2014 5:59 pm
PM sent GB
Thank a lot :D
#12 PostAuthor: Ginger Bear » Mon Feb 03, 2014 6:10 pm
Dave,
I've found the short spring & will post it off to you, sadly I can't help you with the larger return spring. :cry:
DaveZ1
#13 PostAuthor: DaveZ1 » Mon Feb 03, 2014 7:35 pm
Your a star GB thanks a lot.
Steve is having a dozen of the plates laser cut this week
in stainless so no need to zinc plate them. I will send you
one with something else that he has had laser cut for your Z.
Send me your address when you get a minute bud and I will
get them to you soon.
Cheers Dave.
#14 PostAuthor: Ginger Bear » Mon Feb 03, 2014 8:02 pm
That's very kind Dave, my address will be on the back of your jiffy bag.
Z1parR
#15 PostAuthor: Z1parR » Mon Feb 03, 2014 9:50 pm
I have a couple of drain screws , one brass and one steel .
Yours if you still need them Dave .
0172 . Geoff Parr
