Went to set up a Z1R-TC
Big Fluff
#1 PostAuthor: Big Fluff » Sun Nov 17, 2013 4:44 pm
Went over to help a friend out today, setting up his Z1R-TC "Molly" that hadn't been run for 30 years!
As he wants to ride it regularly, I advised him to fit the Mikuni HSR42 carb and Dyna 2000 ignition system, along with an adjustable pressure switch in the plenum to automatically retard the ignition under boost.
I set the timing, set the retard boost switch to 5 psi and set the carb up.
After a bit of spinning the motor over (which has been rebuilt) it fired up no problem.
The Rajay turbo was overhauled by my mate Dave Dunlop (the Rajay turbo god!) and it sounds real sweet.
The fuel height will need setting (hence the small bit of fuel overflowed on the floor) and the oil pressure switch was duff (I'm sending him one over FOC).
It's nice to see a TC in it's original condition, something which my friend intends on how to keep it, not restored!
Whilst I was there, he showed me a few more of his collection....
Harris F1 with 998cc genuine XR69 GS engine (sub 1000cc works engines only had 4 plug head)
A beautiful UK spec RC30 (lower fairings away being painted)
And his pride and joy, a Kawa Z1000R1, modified to his own personal taste and exquisitely done too
I did have to "rib him" over the pink HT leads though, but I thinks that must be his feminine side coming out !:lol:
PJ
#2 PostAuthor: PJ » Sun Nov 17, 2013 5:30 pm
Wow - what a beautiful collection, thanks for sharing Will
#3 PostAuthor: Pigford » Sun Nov 17, 2013 5:49 pm
Phwarrr... hope theres a BIG lock on that garage :wink:
Jay1969
#4 PostAuthor: Jay1969 » Sun Nov 17, 2013 6:31 pm
Very nice Z1R-TC Will :up
Big Fluff
#5 PostAuthor: Big Fluff » Sun Nov 17, 2013 7:10 pm
[quote="Pigford"]Phwarrr... hope theres a BIG lock on that garage :wink:[/quote
Very secure setup indeed.!
I might be getting a Moto Martin Castellet from him yet... fingers crossed.
Z1parR
#6 PostAuthor: Z1parR » Sun Nov 17, 2013 8:16 pm
Nice one Will , what a cracking collection of bikes the guy has :up
Not trying to fuel any fires but i just love that RC30 :drool
0172 . Geoff Parr
neilbarrett
#7 PostAuthor: neilbarrett » Sun Nov 17, 2013 9:22 pm
put a small pump and regulator on the z1r and set the pressure between 2 -3 psi and it should start on about half a crank :wink:id get the fuel mixture checked on a dyno
Big Fluff
#8 PostAuthor: Big Fluff » Sun Nov 17, 2013 10:21 pm
neilbarrett wrote:put a small pump and regulator on the z1r and set the pressure between 2 -3 psi and it should start on about half a crank :wink:id get the fuel mixture checked on a dyno
Neil - Tried that but the HSR carbs will only cope with about 1 psi before it leaks past the fuel valve so no good!
neilbarrett
#9 PostAuthor: neilbarrett » Sun Nov 17, 2013 11:22 pm
some thing wrong then ,my bikes run hsr45s and don't flood til 3.5 + on tickover,what size carb is the z running and if its a 42 is it the turbo spec one ?
marlin
#10 PostAuthor: marlin » Mon Nov 18, 2013 11:00 am
to big fluff , i see you've been over to rob's house who run's the trackdays , really nice and friendly bloke , and dave dunlop i sold him a wiseco big block earlier in the year for one of his turbo jobs , cheers marlin , ps tell your mate cracking z1r tc .
marlin
#11 PostAuthor: marlin » Mon Nov 18, 2013 11:07 am
if i remember rightly his zed as a all singing all dancing 1260 motor , cheers marlin
KWACKERZ1
#12 PostAuthor: KWACKERZ1 » Mon Nov 18, 2013 11:15 am
I always wonder why he rides his H!"$nda on the trackdays with a collection like that,
must give him some stick when i see him!
Big Fluff
#13 PostAuthor: Big Fluff » Mon Nov 18, 2013 12:46 pm
neilbarrett wrote:some thing wrong then ,my bikes run hsr45s and don't flood til 3.5 + on tickover,what size carb is the z running and if its a 42 is it the turbo spec one ?
Neil
I wasn't aware that there is such a thing as a 'turbo spec' HSR ?
The carb on both my Silver Saxon and my mates TC are HSR42 from Allens Performance. Nothing was said about a specific turbo spec carb when ordering....
I bought a 1-2 psi pump and fuel pissed past the valve at it's lowest setting. I even bought a replacement fuel shut-off valve assembly (nitrile tipped) but it made no difference.
Instead I now run a huge fuel tap with 8mm ID outlet and 8mm ID bore hose to the carb. I feel that should be plenty for 'progressive' use :lol:
My mates TC runs a Pingel tap.
Marlin - Yeah Rob's a great bloke and I hope to be supporting some of his events next year with my VJMC section.
KwackerZ1 - Because it's also a bloody good bike!
Jeff Saunders
#14 PostAuthor: Jeff Saunders » Mon Nov 18, 2013 1:31 pm
I now run a 2-3psi fuel pump with a smaller 2.3 float needle valve orifice (recommended by Mikuni for fuel pump setups).
I used to have a separate fuel regulator, but I removed this as I was getting erratic flow.
Most times I don't get issues with fuel pissing out, but once in a while the needle sticks until the bike fires up.
I have my fuel pump on a separate switch to help with the carb getting overwhelmed with fuel. This also serves as a security switch.
Choke is the only issue I have with the HSR 42 on my bike. When very cold the choke circuit doesn't come close to being rich enough, so I have to use the accelerator pump to prime. Two twists of the throttle and it's fire briefly and stall - then repeat until I can get constant feathering of the throttle to keep the bike going until it's warm. I understand the carb can be modified to help here - have you done anything with the choke circuit?
#15 PostAuthor: paul doran » Mon Nov 18, 2013 2:56 pm
awsome collection Your Pal has Will
thanks for sharing it
