kawasaki gpz1100a
bigrocketrider
kawasaki gpz1100a
#1 PostAuthor: bigrocketrider » Wed Oct 23, 2013 8:19 am
I am in the process of restoring a GPZ1100A1. The bike is now back together and running but I can't for the life of me figure out which way operates the choke as it appears to make no difference. Should the choke lever be level when running and up to start the bike?
#2 PostAuthor: z1bman » Wed Oct 23, 2013 9:41 am
its a fast idle not a choke. all the lever does is open the the throttle slightly. the engine temperature sensor + air temperature sensor control the amount of fuel it needs at all temperatures including cold starting. lever should be in up position for it to start from cold although i never used to use the fast idle as it was much easier to warm it up with the throttle until it would tick over on its own
Gavin
#3 PostAuthor: Gavin » Wed Oct 23, 2013 5:14 pm
z1bman wrote:its a fast idle not a choke. all the lever does is open the the throttle slightly. the engine temperature sensor + air temperature sensor control the amount of fuel it needs at all temperatures including cold starting. lever should be in up position for it to start from cold although i never used to use the fast idle as it was much easier to warm it up with the throttle until it would tick over on its own
Same goes for my Z1300 injection
Z1000 MK2
Z1300 DFI
bigrocketrider
#4 PostAuthor: bigrocketrider » Wed Oct 23, 2013 7:45 pm
My first fuel injection resto - and possibly my last at this rate. Done many a carb resto but fuel injection is another ball game altogether. Pipes everywhere and very little info available on the GPZ. For the first time, I wish I had taken phots of where things went as it would have been soooooo much easier. However, got her all back together and running but I just can't seem to be able to synchro the throttle boddies.
Can you just confirm that the fast idle lever should therefore be horizontal for normal running and up to start (if needed).
Cheers guys
garyd
#5 PostAuthor: garyd » Wed Oct 23, 2013 7:57 pm
Cheers guys
Yes, That's correct.
#6 PostAuthor: z1bman » Wed Oct 23, 2013 8:17 pm
i am sure there are some markings + an arrow on the side of the fast idle lever ?
bigrocketrider
#7 PostAuthor: bigrocketrider » Thu Oct 24, 2013 7:44 am
Thanks very much. I was clearly trying to balance the throttle bodies with the fast idle on - no wonder the revs kept increasing. Feel a bit daft now - I can strip and rebuild the bike but I don't know the difference between a choke and fast idle lever!
#8 PostAuthor: chrisu » Thu Oct 24, 2013 9:22 am
at least its sorted now..........
snotie1965
#9 PostAuthor: snotie1965 » Sat Oct 26, 2013 6:59 pm
bigrocketrider wrote:Thanks very much. I was clearly trying to balance the throttle bodies with the fast idle on - no wonder the revs kept increasing. Feel a bit daft now - I can strip and rebuild the bike but I don't know the difference between a choke and fast idle lever!
What was the outcome ? DFi or carbs ???
bigrocketrider
#10 PostAuthor: bigrocketrider » Sat Oct 26, 2013 7:29 pm
DFI. Outcome - Throttle Bodies 3 and 4 balance nicely but 1 and 2 balance but then go out of balance when revved so I can't look to equal out each side using the centre adjustment. It would appear that I have a sticking No2 throttle body and despite several attempts to free it up, I reckon a replacement set is now required. Bit of a pain really but everything else is now spot on with the bike and at least I know it runs with no nasty engine noises (apart from the miss balance that is).
BRIAN S
#11 PostAuthor: BRIAN S » Sun Oct 27, 2013 7:43 pm
I still have the throttle bodies I gave you the flap from
If they are any good to you pay the postage and you can have them
they have been outside for a bit but think they should be ok with a good clean & lube Just pm me if you want them.
Brian
GPz1100B1
bigrocketrider
#12 PostAuthor: bigrocketrider » Mon Oct 28, 2013 9:37 pm
Definately want them Brian. PM sent
Users browsing this forum: gpzer, r3sc and 53 guests
