Underslung Rear Caliper conversion on a Z1R
Fred the Zed
#1 PostAuthor: Fred the Zed » Tue Jul 23, 2013 5:30 pm
Hi
For reasons I won't go into, I'm thinking of converting the heavy, chunky, ugly caliper and disc arrangement on my Z1R to something a little slinkier looking and underslung. I understand that the torque arm mounting on the swingarm needs swapping to the underside from it's current position but don't worry, I can sort that easily enough.
I was looking at either a disc, caliper and carrier off a ZRX1100, ZXR750 or ZZR1100 for the mod. I want to keep the original wheel. Has anyone else out there done an underslung rear brake caliper conversion on a Z1R / Z1000 who can offer some advice please?
Fred
Paid Up Member
KeithZ1R
#2 PostAuthor: KeithZ1R » Tue Jul 23, 2013 8:17 pm
Think Chrisu is your man
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Z1parR
#3 PostAuthor: Z1parR » Tue Jul 23, 2013 8:31 pm
Pigford or GB will have ideas on this too , i should think .
There's a few serial modding types about on here :D
0172 . Geoff Parr
#4 PostAuthor: chrisu » Tue Jul 23, 2013 9:13 pm
KeithZ1R wrote:Think Chrisu is your man
mine is a brembo baked into the single sided hub so very off piste.
#5 PostAuthor: Ginger Bear » Fri Jul 26, 2013 12:22 pm
The Tokico caliper you are talking of was fitted to many bikes, ZX7R GSXR600/750 SRAD Early Busa's etc.
You might be able to use the complete caliper & carrier assembly, just sleeving down the spindle hole on the carrier & modding spacers to get the caliper in line with the disc.
I'm sure the disc mounting holes wont line up, so you may have to re-drill it, or make some sort of adaptor plate. or have a 'one off' disc made.
If you don't or can't use the existing carrier, it wouldn't be too hard to make a new one, from something like 10mm aluminium plate/bar.
Fred the Zed
Thanks for the advice
#6 PostAuthor: Fred the Zed » Sat Jul 27, 2013 7:04 am
Thanks for the advice guys... I'll apply my mind to what will perform / look the best.
Fred
Paid Up Member
#7 PostAuthor: Ginger Bear » Sat Jul 27, 2013 12:15 pm
Just found this pic on Ebay...... Thought it might give some inspiration.
Fred the Zed
#8 PostAuthor: Fred the Zed » Sat Jul 27, 2013 7:24 pm
Sweet
Paid Up Member
big green bus
#9 PostAuthor: big green bus » Mon Jul 29, 2013 8:51 pm
Put an ap calliper and brembo master cylinder on mine and it would not hold it on a hill ! You need to make sure you get the ratio correct or you will have no brake or a one that locks with the lightest touch
Fred the Zed
#10 PostAuthor: Fred the Zed » Tue Jul 30, 2013 5:20 am
Good point, well made!
Can you post a picture of it up for me to see? How did you sort out the hanger arrangement?
Fred
Paid Up Member
#11 PostAuthor: Ginger Bear » Thu Aug 01, 2013 3:06 pm
Fred,
I took a couple of pics of Jak's version last weekend....... Just for you!
Notice the use of small washers/shims to get the caliper central to the disc.
Fred the Zed
#12 PostAuthor: Fred the Zed » Thu Aug 01, 2013 6:00 pm
Hey Ginger Bear
That was very decent of you. It's a project that will take a little thought, but should be worthwhile in the long run.
Are Jak & Big Green Bus one and the same person?
Once again, thanks for the photos and pointers.
All the best
Fred
Paid Up Member
hillbilly
#13 PostAuthor: hillbilly » Thu Aug 01, 2013 7:46 pm
just to let you know,i have a brembo on my yellow beasty,its upside down,thing i found out.was that it wouldn't bleed up properly,so i had to de mount it,put it on the top of disc,then bleed it,then put back on at bottom.
#14 PostAuthor: Ginger Bear » Thu Aug 01, 2013 8:05 pm
Definitely NOT. :no :no But both 'TOP' blokes all the same.
Big Fluff
#15 PostAuthor: Big Fluff » Fri Aug 02, 2013 7:05 am
If you do go ahead with this conversion, you may want to think about making the caliper floating, and attaching the torque arm to the frame.
If you fasten the 'short' torque arm to the swing arm then it's straight forward enough, but as you know, when the brake is applied the rear end will dip.
In previous bikes (inc. my old Moto Martin) I turned a bush within the caliper carrier, so that when the rear wheel spindle is pinched up, the caliper and carrier bracket are free to swing 'float'. Fabricating a longer torque arm and fastening to the underside of the frame will then allow you to brake with no dipping of the rear end.
It's all down to personal preference but much prefer the feel of a floating rear brake.
Will
