flickering oil warning light
What happens is on idle or low revs the oil light flickers. Rev it up and it goes out, but even then it occasionally comes on when riding along.
Allways been a problem on my Z1B but recently was getting worse so I fitted a new switch but this fault still remains.
Any thoughts? pointers?
1972 Z1 Euro Spec
1975 Z1B UK Bike
1972 Z1 Euro Spec
1975 Z1B UK Bike
wilsonsjw11
wilsonsjw11
When re fitting, lube new gasket with a bit of grease and it will come off easier next time. Dont over tighten small sump bolts when refitting. Honestly take your time and its easy i learnt all that on here............. hopefully No siezed bolts and exhaust comes off without too much pain.
Andy
Z1 Blocked Strainer
Totally agree that's your problem, do not use until sump strainer is cleaned, I had that once in my early Zed days, I also noticed a drop in power, luckily no damage was caused thanks to the Roller crank..... possibly some wear to cam half shells, cant remember, but I am sure these are the first to get punished with a blocked strainer it was a long long time ago, regular oil change / and filter, quality oil, spotless filler funnel, clean oil, you know the script.
Also sludge was mentioned, its usually a combination of not getting the engine really hot, (give it a good thrashing now and again) and just to re-word, the tech term is not getting it up to operating temp, also use of low quality oil with little in the way of additives, not good, these guys who don't use their bikes and just start them once a month to LOOK AFTER IT are the worst culprits for premature engine wear
Always Learning.
I am having same problem.
With hot engine the light was on below 3000 rpm.
I have replaced the oil pressure switch. Now light is off with cold engine.
It turns on with hot engine (after 15 minutes) but only at idle rmp. Above 1500 rpm is off.
My oil is Motul 5100 10w40. Since I am using this bike only in summer (north of Italy) I was thinking to replace with 10w50.
I had simular problem with one of mine. put new switch on it and it still flickered and came on some times at tickover. You can put an extra washer on the plunger as i found it wasnt earthing properly. I also put my finger in the hole and pulled out a small bit of gasket that was stopping it earth. Ive had no probs since.
Z1b,
zxr750 m2,
zrx1200
Z1000j lawson race bike,
Versys 1000gt (2019),
zxr750 m2,
zrx1200
