Z1000J & Z1000R2 front disc size
Plumba 54
#1 PostAuthor: Plumba 54 » Sat Jun 17, 2006 1:48 pm
Can anybody tell me if the disc size is the same,or at least should be, on the J and the R2.I have just tried putting a set of forks off a J onto the R2 and all was ok until i put the front wheel on.The discs are actually touching the body of the caliper holder and are around 3 mm to big.The discs on my GPZ1100 are the same diameter as those on the R2.If they are meant to be the same size the only thing i can think of is that the forks of the J are off an earlier model that may have had smaller discs, or the discs on the R2 are not standard size.
Big John
#2 PostAuthor: Big John » Sat Jun 17, 2006 4:00 pm
I think Jack had the same problem, J1 and I think J2 discs are different to J3 and R2 discs
Plumba 54
#3 PostAuthor: Plumba 54 » Sat Jun 17, 2006 4:38 pm
Cheers John,Jack you confirm this and what did you do to rectify it.Could have the old forks re chromed and re use them i suppose, anyone recommend anybody that aint gonna mean i need a second mortgage? Where are you in my moment of need Mr Smith?
Big John
#4 PostAuthor: Big John » Sat Jun 17, 2006 7:41 pm
Dale, have you tried the original wheel and discs/calipers combination with the J forks ?
Plumba 54
#5 PostAuthor: Plumba 54 » Sat Jun 17, 2006 9:52 pm
Hi John, its the original discs,calipers & wheel off the R2 that i put onto the J forks/stantions.Dont have the ones from the J so have no way of telling if they are different. Did also think about using the stantions from the R2 and putting them on the J forks,would,in theory only then need to but a set of fork seals and oil,providing of course Mr Kawasaki hasnt made them a different diameter as well! Open to suggestions
#6 PostAuthor: chrisNI » Sat Jun 17, 2006 10:34 pm
There's a different part number for the J1/2 and J3 stanchions and brakes. The early ones have an A after the number, the J3 and R2 part numbers are the same with no A.
Plumba 54
#7 PostAuthor: Plumba 54 » Sun Jun 18, 2006 8:59 am
had a brain wave last night and this morning i have put the spare wheel (off a J) i got with the bike on the R2.Although the discs are in pretty poor condition it all fits correctly. These discs have 2C 33 on them, the ones on the R2 have 3A 38 on them.The bolting pattern for putting them on the wheels looks the same,should they in theory then be ok to put on the R2 wheel and be safe to use if i get them cleaned up or can source some others?
Iain marshall
#8 PostAuthor: Iain marshall » Sun Jun 18, 2006 4:08 pm
got a list of EBC discs,it doesnt give you sizes but tells you which ones are the same
Part No. Description Model/Year
MD 4006 LS Brake Disc (EBC Front Left) Kawasaki Z 1000 J1-2 & K1 81-83 ?62.50 Add
MD 4038 LS Brake Disc (EBC Front Left) Kawasaki Z 1000 J3 & R2 83 ?105.00 Add
MD 4064 LS Brake Disc (EBC Front Left) Kawasaki Z 1000 A1-A4 & H1 74-80 ?156.45 Add
MD 4076 LS Brake Disc (EBC Front Left) Kawasaki Z 1000 D1-3 78-79 ?156.45 Add
MD 4078 LS Brake Disc (EBC Front Left) Kawasaki Z 1000 ST 79-82 ?156.45 Add
MD 4006 RS Brake Disc (EBC Front Right) Kawasaki Z 1000 J1-2 & K1 81-83 ?62.50 Add
MD 4038 RS Brake Disc (EBC Front Right) Kawasaki Z 1000 J3 & R2 83 ?105.00 Add
MD 4064 RS Brake Disc (EBC Front Right) Kawasaki Z 1000 A1-A4 & H1 74-80 ?156.45 Add
MD 4076 RS Brake Disc (EBC Front Right) Kawasaki Z 1000 D1-3 78-79 ?156.45 Add
MD 4078 RS Brake Disc (EBC Front Right) Kawasaki Z 1000 ST 79-82 ?156.45 Add
MD 4054 Brake Disc (EBC Rear) Kawasaki Z 1000 J1-J3 & K1 & R2 81-83 ?105.00 Add
MD 4077 Brake Disc (EBC Rear) Kawasaki Z 1000 A1-4 & D1-3 & H1 74-80 ?135.45 Add
MD 4090 Brake Disc (EBC Rear) Kawasaki Z 1000 ST 79-82 ?105.00 Add
PPT 236770 Brake Disc (SS Front) Kawasaki Z 1000 J1-J2 & K1 81-83 ?80.00 Add
PPT 236960 Brake Disc (SS Front) Kawasaki Z 1000 R2 83-84 ?90.00 Add
PPT 236963 Brake Disc (SS Rear) Kawasaki Z 1000 J1-3 & K1 & R2 81-85 ?80.00 Add
Plumba 54
#9 PostAuthor: Plumba 54 » Sun Jun 18, 2006 8:24 pm
Cheers Ian if i cant get the other discs cleaned up ok i have the info i need to get new ones. Have had a play around with the discs and they do interfit ok, buggers to get off, thank god for wooden mallets!
JACK THE LAD
#10 PostAuthor: JACK THE LAD » Wed Jun 21, 2006 4:57 pm
The front disc sizes are 270mm for the J1,J2 and GPz1100B1.
It is 280mm for the J3,GPz1100B2 and Lawson 1000R2/1100R1.
The fork bottoms are slightly different on the later models to provide clearance for the larger discs.The bottom mounting lug is offset slightly to increase the radius for the caliper.
I shall be choosing this as one of my specialist subjects on Mastermind.
Users browsing this forum: No registered users and 107 guests
