I assume it is pressed down out of the bottom of the yoke.
I was looking for tips on t'interweb and found this...
http://pantablo500.tripod.com/id11.html
Please tell me he didn't use aluminium duct insulating tape to pack the hole between the bottom yoke and stem and then go racing!!!!
Cheers,
Mark.
Pressing out a steering stem
needaz1100r
- ZedHead
- Ginger Bear
You are correct. If it can be pressed out it will go downwards.
Oddly enough, I've just posted this on another thread;
This is what I did the last time I needed to modify a stem. came from a Z1000J & was welded.
1. Cut off what you can.
2. Stick it in a lathe......... even a 'baby' Myford will do.
3. Machine it to fit your replacement bottom yoke.
This method is particularly useful if the replacement yoke was fitted with a larger diameter stem. Note the small 'lip' left on the bottom of the stem to stop it being 'pulled' through the yoke.
needaz1100r
- ZedHead
- Ginger Bear
Users browsing this forum: No registered users and 102 guests
