Z1 Small Tank Badges
Does anyone know if it's possible to drill and tap a Z1A/B tank to accept the smaller 73 Z1 tank badges?
wilsonsjw11
Thanks Steve, i have seen the Doremi replica tanks with the multi fixing for both which is why I asked if it could be done on an original tank. Z1A and Z1b should be identical to the Z1 tank apart from the badges shouldn't they? ie. Narrower neck, inboard seam and hook for the tank rubber. Did these features change in 76 Z900A4s or was it earlier?
Cheers, Dave.
Cheers, Dave.
wilsonsjw11
Guys,
There is a nice Z1 tank guide on Jeff's website here for you -
http://www.z1enterprises.com/Z1TankGuide.aspx
Far as I know this is all good info. Please advise if you spot any errors.
Good reference pics for you Dave.
From Mark
From Mark
