size 20 pilot jets
size 20 pilot jets
has anyone got a set of 4 size 20 pilot jets they want to part with. Happy to swap for a set of 17.5s................
- Jeff Saunders
the ones in the picture will ONLY fit the 73 and early 74 Z1 carbs.
They are VM28/213 series - unique to the early Z1's. The VM28/486 series is what you need.
The easy way to tell them apart is the 6 bleed holes in the early ones and 8 in the later ones found on all other VM26 and VM28 carbs.
