Z9/Z1000 frame brackets
#1 PostAuthor: paul doran » Sat Jan 21, 2012 4:16 pm
has Anyone got a scrap frame for either a Z9 or Z1000
I need the brackets that the grab rail bolts to
it can also take the indicators if needed
Z903
#2 PostAuthor: Z903 » Sat Jan 21, 2012 10:32 pm
Was looking for these myself some time ago, have since found some but was offered a pair a couple of days ago. So if you get stuck I should be able to put you on to them....trouble is, they'll be in Australia
z1000puddin
#3 PostAuthor: z1000puddin » Sat Jan 21, 2012 10:45 pm
Paul,
The brackets are welded to the frame - yeah ?
I can make a set up so you can weld them on if that would do ??
Unless it is originality that you are looking for
stu
Zed til Dead
#4 PostAuthor: paul doran » Mon Jan 23, 2012 2:10 pm
Stu mine ar cut in half I can make up something Myself if I dont get a set
We have an Engineering Business so it wont be a problem
z1000puddin
#5 PostAuthor: z1000puddin » Mon Jan 23, 2012 8:48 pm
No worries Paul,
BTW,
What is your capacity on the machining department, do you have a website ?
We are always on the lookout for good quality machine/engineering shops for a number of projects.
Stu
Zed til Dead
#6 PostAuthor: paul doran » Mon Jan 23, 2012 8:52 pm
We have two Lathes and two milling machines and a fabrication shop
and a couple of large hydrulic presses
We also have access to a CNC Lathe and Mill
We also have a fabication shop
We do not have a website as believe it or not we dont advertise
We have never found the need to thankfully
#7 PostAuthor: Ginger Bear » Mon Jan 30, 2012 3:33 pm
These any good to you Paul? they're from an LTD frame. :shock:
#8 PostAuthor: paul doran » Mon Jan 30, 2012 3:40 pm
those would be ideal Steve
#9 PostAuthor: Ginger Bear » Mon Jan 30, 2012 3:42 pm
Ok Paul, if you're not going to Donny, let me have an address to send 'em to. If you are going to Donny, I'll bring 'em with me.
#10 PostAuthor: paul doran » Mon Jan 30, 2012 3:49 pm
Steve Donington looks less likely too busy
can You send them to
Paul Doran
DW Engineering
Unit 9 Ashcourt
Ashbourne Ind Estate
Ashbourne
Co. Meath
Ireland
cheers Steve
I will get You a few beers when we meet
#11 PostAuthor: Ginger Bear » Mon Jan 30, 2012 3:55 pm
Sounds good to me Paul. :beer
I'll go & get the grinder out. :sou
