Cylinder head wanted. Z9/1000 or maybe even complete engine.
#1 PostAuthor: zed1015 » Fri Dec 02, 2011 5:02 pm
Good usable cylinder head wanted.
Anything from a Z9 /1000/ st /mk2 or even a 1000J.
If mk2 or J must have cam cover also.
Just got a motor in for rebuild and the current head is so bodged and worn (6 bent valves /ground shims /broke exhaust stud castings/no location dowels / imperial bolts forced in etc all recently caused/done by top harley mechanic :shock: ) it will be cheaper to just replace it.
Anything considered.
Update - Complete engine considered after discovering even more Hog brother inflicted horrors lurking inside :( .
hillbilly
#2 PostAuthor: hillbilly » Sat Dec 03, 2011 12:27 pm
i have some heads,but no cam caps,if you can use one,i might swap for something.
zman
#3 PostAuthor: zman » Sat Dec 03, 2011 1:14 pm
keep thoses wheels turning
shaggy
#4 PostAuthor: shaggy » Sat Dec 03, 2011 4:40 pm
I definitely have a 1000 head somewhere and other bits as as i stripped down a whole z1b motor mainly for the z1b head let me know what you need may have all of it
Ta aul
#5 PostAuthor: Pigford » Sat Dec 03, 2011 4:41 pm
PM sent - full motor available :wink:
#6 PostAuthor: zed1015 » Sat Dec 03, 2011 7:35 pm
Thank for the PM's etc will be in touch once i've consulted with the bikes owner.
Re: Cylinder head wanted. Z9/1000 or maybe even complete eng
#7 PostAuthor: Ginger Bear » Sun Dec 04, 2011 9:59 am
Any pic's Rob :?
#8 PostAuthor: Pigford » Sun Dec 04, 2011 11:39 am
....blimey Bear, I bet you're one of those people that slow down past the scene of a RTA to get a good look at the grusome details :|
#9 PostAuthor: Ginger Bear » Sun Dec 04, 2011 11:48 am
Deffo NOT Piggy, :pok but I would be interested to see what sort of butchery a HOG Head can do. :lan
#10 PostAuthor: zed1015 » Sun Dec 04, 2011 11:50 am
No pic's. Owner might not want the publicity.
But to give a rough idea.
Harris Mag 1428, rebuilt motor by "said" Harley bro.
Owner trailers bike home as it's not fully finished and as it's a long termer just keeps spinning it over once a week to keep it oiled and free.
One day it sounds odd and spins over very fast.
Eventually ends up on my doorstep.
Turns out Harley man missed out the one way ballbearing ring in the tensioner hence six bent valves but also left out all the location dowels for the head/barrel and cam caps and on top of that he's bust an exhaust stud casting so wedged in an odd rusty imp threaded bolt, ditto with two capcap bolts + all the cam train components are past knackered and thats just the topend highlights.
There's also an inch wide gouge in one of the freshly bored liners so he's probably bust a ring when slapping it together.
Not got any further pulling apart (but it don't look promising) as i've got two other Zed motors to rebuild before i have the space to spread this one out.
#11 PostAuthor: Ginger Bear » Sun Dec 04, 2011 12:01 pm
Ooh......... Nasty. :lar
bart
#12 PostAuthor: bart » Sun Dec 04, 2011 1:47 pm
garyd
#13 PostAuthor: garyd » Sun Dec 04, 2011 5:04 pm
Fancy a big bore with head work....
http://www.ebay.co.uk/itm/200680794378? ... 1436.l2649
£200 at the moment
