Newtronic Ignition?
uk kev
Newtronic Ignition?
#1 PostAuthor: uk kev » Mon Apr 16, 2007 4:23 pm
Do any of you have a Newtronic ignition fitted, if so, could you tell me where the blue wire goes please...
Big Fluff
#2 PostAuthor: Big Fluff » Mon Apr 16, 2007 4:44 pm
Goes to earth - definitely.
White - Ignition (switched), connect to Orange/White on your Suzuki
Blue - Earth, connect to Black/White on your Suzuki
Yellow - 1&4 coil input, connect to White on your Suzuki
Purple - 2&3 coil input, connect to Black/Yellow on your Suzuki
Regards, BF.
Big Fluff
#3 PostAuthor: Big Fluff » Mon Apr 16, 2007 4:47 pm
Sorry about leaving the Susook bits in there..... It's the same for the Kawasaki models anyway
White - Ignition (switched), connect to Brown on Kawasaki
Blue - Earth, connect to Black/Yellow on Kawasaki
Cheers.
uk kev
#4 PostAuthor: uk kev » Mon Apr 16, 2007 4:54 pm
Thanks for that BF.
Z1B Alan
blue wire
#5 PostAuthor: Z1B Alan » Mon Apr 16, 2007 4:56 pm
Ihave the same system on my z1b the blue wire runs to earth on the frame :D
uk kev
#6 PostAuthor: uk kev » Mon Apr 16, 2007 5:15 pm
That's great thanks guys,I knew I could count on the forum for help.
#7 PostAuthor: Pigford » Mon Apr 16, 2007 7:00 pm
Best to get a very good earth, direct to battery is favourite :wink:
remember to time in low light, ideally in garage with door shut. Sun light confuses optical sensors & put timing out. :|
Z1B Alan
#8 PostAuthor: Z1B Alan » Tue Apr 17, 2007 6:33 pm
uk kev hope this image helps you locate the ignition box
the picture is of the left hand side of the bike
uk kev
#9 PostAuthor: uk kev » Tue Apr 17, 2007 6:54 pm
Thanks Alan, I will move mine this weekend, I can't see why the guy tried to fit it where he did?
Kevin.
Jon
#10 PostAuthor: Jon » Tue Apr 17, 2007 7:19 pm
Yup deffo earth. Got same system on Harris. I earthed to solid earth on frame under tank. Wee bit suceptable to water ingress these units, but I bagged mine up on elecs tray under tank to keep water out. Water blew one of the switching diodes on me few hundred miles from home on remote scottish island few years back. RAC to the rescue again. :lol:
No probs since tho and she`s seen some shitty weather. :wink:
